after effects transition problem at DVinfo.net
Adobe Creative Suite
Old April 23rd, 2011, 04:13 AM   #1
first of all,why doesnt after effects renders transitions used in premiere.it only recognises cross disolves and not dip to blacks.how do i go about this.
Olabode Lawal is offline   Reply With Quote
Old April 24th, 2011, 02:42 AM   #2
Re: after effects transition problem
You can create fades and dissolves using the "opacity" property with keyframes. After effects will read these keyframes correctly.
Jon Shohet is offline   Reply With Quote
Old September 19th, 2011, 09:10 AM   #3
sorry how do i crossfade with keyframes in adobe premiere
Old September 19th, 2011, 09:46 AM   #4
Line up the clips so they overlap on the timeline, and then dissolve the other clip overtop of it from 0-100% with the duration you want from it (default is 1s or ;30 frames).
After effects will pick that up no problem when your switching things back and forth. Had this same problem before and had to adjust how I did things a little bit.
Justin Molush is offline   Reply
