Premiere problem at DVinfo.net
Adobe Creative Suite
Old March 19th, 2011, 06:54 AM   #1
Premiere problem
Editing in Premiere Pro 2 with Matrox RTX2 I find that Paste Attributes is greyed out and Audio Transitions does not work. I have tried the delete preferences trick but to no avail. Any ideas would be most welcome.
Premiere CS5, EX1, 2xFX1,SonyA1,GlideTrack.
Last edited by Mike Wade; March 19th, 2011 at 06:55 AM. Reason: I replaced a missing word - 'tried'.
Mike Wade is offline   Reply With Quote
Old March 19th, 2011, 04:02 PM   #2
Re: Premiere problem
Try without Matrox. That will probably solve all your problems.
Old March 19th, 2011, 04:47 PM   #3
Thanks for the suggestion, although it sounds a bit drastic. Is there an easy way to 'switch Matrox off' ?
Old March 19th, 2011, 06:49 PM   #4
Hey Wade....
You have to physically select all the effects in the "effects panel", and press "CTRL-C", highlight the next clip, and right click "paste attributes"...
Old March 20th, 2011, 04:46 AM   #5
Brilliant Peter ! Paste Attributes now works after following your suggestion but still no luck with the Audio Transitions....
Old March 20th, 2011, 09:22 AM   #6
Firstly, let's define audio transitions...
It's the fade in/out between audio clips, or at the beginning/end of same clips...
Are we on the same page?
If so, go to the Track number on the left side side, and highlight the Audio Track number that the clip resides in.
Once you've done that, to to the beginning, or end of the audio clip (page up/down).
Instead of pressing "CTRL-D", like you would for a video transition, you need to press "Shift-Ctrl-D" to activate it..
Old March 20th, 2011, 10:06 AM   #7
Yes that's what I meant by 'audio transitions' and yes, once again you have the answer. You are a star, Peter, thanks a lot.
