Can multiple sequences from several projects... at DVinfo.net
Adobe Creative Suite
Old March 2nd, 2011, 08:14 PM   #1
...be imported to form the nucleus of an entirely new project?
If so, how is it done?
Anotherwords, I want to:
Take a sequence from one project and
another sequence from a 2nd project and then
in essence "marry" them to use in a new project.
It will be very usefull to know how to do this.
Thanks in advance.
Bruce Pelley is offline   Reply With Quote
Old March 2nd, 2011, 11:35 PM   #2
Re: Can multiple sequences from several projects...
Open a new project and blank sequence.
Then: file> import > select type as Premiere Pro Project. Directory will open up for you to select the first project you want to import. Then select from the popup either all sequences in that project or selected sequence(s) and import the sequence(s) you want.
Then do the import part again for the other project(s) you want to add.
Battle Vaughan is offline   Reply
