Combine separate Audio & Video Files at DVinfo.net
Adobe Creative Suite
Old January 26th, 2011, 05:51 PM   #1
I used the CS4 encoder and exported a project using Jeff Bellune's recommendations to get a very high quality DVD.
It resulted in two separate files. Video file is .m2v and audio file is .wav
Looks great when I view it using Windows Media Player, but the files are separate.
How do I get these two files together to burn a DVD?? Can I do that with ImgBurn or Nero, or Roxio ??
Here's his tutorial. Bellune Digital Video Services - Play Video - Adobe Premiere Pro - HD to SD Using Premiere Pro CS4
Tom Blizzard is offline   Reply With Quote
Old January 27th, 2011, 01:15 AM   #2
Tom,
On export you set multiplexing on (one file) or off (two files). Encore likes elementary streams (two files) better than multiplexed transport streams.
Old January 27th, 2011, 07:43 AM   #3
Thanks Harm. Even though you don't know it, you have helped me out with many things several times in the past.
You must be a very patient fellow.
I need a little more help with this. I exported "Media" using the Cs4 encoder.
I have not used Encore.. yet.
In the encoder and looking at "Basic Settings", "Multiplexing" I see two choices :
Either: " DVD " or " None " I believe I picked DVD. I don't see a choice of "On" or "Off"........ maybe that's "understood" ??
OK I just used Dynamic Link and took my project to Encore and I don't seem to have the vast choices I did with the media encoder. I don't see "Multiplexing" in Encore. ?????????
Thanks again, Tom B.
Old January 27th, 2011, 09:23 AM   #4
Tom,
I no longer have CS4 installed, but here is where you set multiplexing on or off in CS5.
Old January 27th, 2011, 10:16 AM   #5
That does answer my question. As a former teacher, all I can say is: You get an A+ for the day. :)
thanks again
Old January 27th, 2011, 04:21 PM   #6
And if you take your Premiere timeline into Encore using Dynamic Link, you do not need to worry about the multiplexing setting.
Kevin Currie is offline   Reply With Quote
Old January 27th, 2011, 07:21 PM   #7
That is always a dilemma, do you go for the 'Quick-and-Dirty' approach of DL'íng to Encore, or do you choose your own encoding settings. Personally, I prefer the manual settings in AME, but for the most important reason of all, that only AME allows 5.1 AC3 if you have the Minnetonka SurCode plug-in. DL is limited to stereo AC3.
Old January 28th, 2011, 01:29 AM   #8
I don't have the SurCode yet, but is good know. Thanks again, Harm.
