How much Memory for Production Prem at DVinfo.net
Adobe Creative Suite
Old December 25th, 2010, 03:28 AM   #1
Will be getting CS5 PP soon will be editing mostly AVCHD my PC in Intel i7 with 6gigs of memory video card is a Nvidia GTX 470 which I just picked up but can not get the drivers to load I may have to take it back. Using a 1TB system drive and two 1TB drivers set for raid 0 for media dirve. My question is, will 12 gigs of memory be ok? Should I add another hard drive?
Kenneth Maultsby is offline   Reply With Quote
Old December 25th, 2010, 06:15 AM   #2
I run the CS5 Production Premium and my computer has an i7 processor, 6GB DDR3 Ram, 1TB HDD & GTX460 card and it handles native AVCHD fine. I am however looking to add more HDD's to run my software & files off seperate drives, as well as adding more RAM.
Ollie James is offline   Reply With Quote
Old December 25th, 2010, 08:37 AM   #3
For AVCHD memory is crucial. Upping it to 12 or 24 GB will make a noticeable difference. That does not mean you can get by with your current disk setup. It is borderline and you would profit from one or more extra disks, but in your case memory is more important than disks.
Old December 25th, 2010, 02:53 PM   #4
What about ram speed
Does ram speed and type make much of a difference? 1066 1333 2000Mhz speed? And back to hard drives would this be a good setup?
One 1TB OS
One 1TB render files
Two 1TB raid 0 for media
OH Marry Christmas to All :)
Old December 25th, 2010, 03:50 PM   #5
Adobe Systems
I agree with Harm.
12GB seems to be the amount of RAM at which working with demanding formats (like AVCHD and RED) in After Effects and Premiere Pro simultaneously (as with Dynamic Link) becomes smooth and efficient. I have 24GB in my home computer for this purpose. I have 12GB in my work computer.
Todd Kopriva, Adobe Systems Incorporated
After Effects quality engineer
Todd Kopriva is offline   Reply With Quote
Old December 26th, 2010, 12:33 AM   #6
Kenneth,
Memory speed, especially for AVCHD material, is more important than the timings. DDR3-1600 is faster than DDR3-1333, even if the CL were lower, say 9 versus 7. However, it does require manual setup in the BIOS to use the rated speed. If you don't do that, your memory will only run at DDR3-1066 for the i7-920/930/950.
The disk setup you mention is a decent starting point. The first improvement would be to get a 320 GB Samsung F4 for OS & programs, instead of wasting a whole 1 TB disk for that and using a freed 1 TD disk for projects and export.
Old December 28th, 2010, 07:25 PM   #7
I have a 300GB 10k Hard drive and a 2 TB in the computer I just ordered. I also have a 2TB Graid. What would be the best place to put CS5, OS, video files. Thanks!
Marc Brackhahn is offline   Reply With Quote
Old December 29th, 2010, 12:29 AM   #8
On your Velociraptor.
Old December 29th, 2010, 01:47 PM   #9
Thanks Harm! Should I seperate them. I think the OS will be on the 10K. Should I put CS5 there also or put it on the internal 2tb and keep my projects on the G raid?
Old December 29th, 2010, 03:56 PM   #10
OS & Programs on the Velociraptor. Do not try to install programs, especially CS5 on another drive than the default one. CS5 and previoius versions are rather particular in that regard.
Old December 29th, 2010, 07:58 PM   #11
Thanks again Harm!
