LooksBuilder failed to launch at DVinfo.net
Adobe Creative Suite
Old December 22nd, 2010, 02:54 AM   #1
Hello,
I have magic bullet on my AE and Premiere CS5. I was using Magic bullet without any problem but suddenly one day it just stopped working. I apply the effect on a clip and when I click "edit look", the application open for a second and then it dissapears. The application is still open in my dock but it doesn't give a preview image to work with the look. I use an iMac i7. Everything is fully updated.
Is there anyone who solve this problem?
Thank you,
Ilias
P.S: Sorry for my bad English!
Ilias Papaioannou is offline   Reply With Quote
Old December 22nd, 2010, 08:42 AM   #2
Hi Ilias
I had similar problem on a Windows machine. When I had an other program using same time monitor card (MSI Afterburner) and AE running with LooksBuilder. It was same with Vegas Pro, Pr and AE.
I did close MSI Afterburner and everything was ok.
Hannu Korpinen is offline   Reply With Quote
Old December 22nd, 2010, 12:12 PM   #3
I run looks through fcp and sometimes it will do the same thing. I have found that if I click on edit and it does nothing, then I just have to click on the track within my sequence and it "Magically" opens. Try that or reinstall.
Brandon Barnard is offline   Reply With Quote
Old June 29th, 2011, 08:33 AM   #4
Re: LooksBuilder failed to launch
I solved similar problems by shutting down completely my virus protection program. In my case I use System Suite 11 from Avanquest. You might also want to unplug your internet cable when you do this.
Tom Fales is offline   Reply
