How to DEL several audio clips @once in CS5 at DVinfo.net
Adobe Creative Suite
Old December 11th, 2010, 06:08 PM   #1
I would like to know how to delete several audio clips at once in time line in APPro CS5? Please advice step-by-step procedure. your help is much appreciated. Thanks
Pushpa-Brisbane-Australia
Dell Dimension 8400;2.8GHz, 2GB RAM, Win XP with SP3, 1TB HDD;Sony PMW EX1 VideoCamera
Pushpanatha de Silva is offline   Reply With Quote
Old December 11th, 2010, 06:17 PM   #2
You can select each by clicking on one then press the shift key and select each clip in turn, then press delete. If the clips are together you can click and drag to highlight them then press delete.
David Jonas is offline   Reply With Quote
Old December 11th, 2010, 08:29 PM   #3
If the audio clips are linked to the video, hold alt to select only audio. And if they're scattered across the timeline, hold both alt and shift to select.
Zoran Vincic is offline   Reply
