CS5 faster than CS4 on a slower system? at DVinfo.net
Adobe Creative Suite
Old August 25th, 2010, 11:26 AM   #1
This article CS5: Should You Upgrade? ANIMOTION mentions the following
Benefits
64bit: In a 32bit program, the maximum memory (RAM) that can be used is 3 GB. Photoshop, Premiere Pro and After Effects CS5 are 64bit programs and can use all of the memory in your computer. This makes the program more stable and faster, especially with complex projects.
Can anyone confirm this? I'm on the fence about upgrading because I only have 4gb of ram.
Joe Riggs is offline   Reply With Quote
Old August 25th, 2010, 11:41 AM   #2
I can confirm that I can use cs5 on my Toshiba qusmio celeron laptop with 2 gb ram - cs4 cannot playback any HD files - no problem in CS5. My experience is that my computers that cannot handle cs 4 - works with cs5. Offcourse this will not do on all computers that cannot handle cs4 - like a 286 with 4 Mb ram.....
You gain a lot, just getting a 64 bit program.
Bo Skelmose is offline   Reply With Quote
Old August 25th, 2010, 11:44 AM   #3
Wow! That is interesting.
Old August 25th, 2010, 11:44 AM   #4
Benefits
Premiere Pro CS5 can use all of that RAM - and the more RAM you add, the better. In fact, with only 4GB of RAM installed, CS5 does not run sufficiently better/faster than CS4 to justify the upgrade.
Randall Leong is offline   Reply With Quote
Old August 28th, 2010, 08:41 PM   #5
Actually, I found the Mercury Playback Engine to be worth the price of the upgrade from CS4 to CS5, even on a Dual Core system with only 4 Gigs of RAM. Drop in a NVidia card with CUDA support and CS5 will really perform better than CS4. I did this with a couple of our older Dual Core systems.
David Knarr is offline   Reply With Quote
Old August 30th, 2010, 05:14 PM   #6
I'm on the fence with this one...
Do i upgrade to CS5 on my older HP workstation?
I'd gladly drop the Matrox card for a Cuda card if i felt comforatable knowing that my system could run faster.
I'm cutting HDV for the most part....
Peter Manojlovic is offline   Reply
