#16 |
Randall is 100% correct on the ram requirement. Someone with a 768MB card learned this early on in the 'hack' thread.
Something else to consider is the warranty. Some have a few years and some have lifetime (PNY & EVGA, I think). |
#17 | |
I just ordered the above Card from Newegg.com. I was impressed with what I read. Plus the fact that it's in my price range. I report back after I install it and put it to use. Thanks again for all your replies. Harry |
#18 | |
To the OP (Harry): Excellent call on the 1GB GTX 460. However, the few results currently in the PPBM5 list on their Web site for the GTX 460 is slower than most other MPE-enabled cards because the currently available drivers for that card are not mature enough. To everybody who responded to this thread: IMHO a GTX 260 or higher is the best choice for CS5. Lower-class cards with 1GB or more RAM are not as good, but still provide a significant boost. The worst choice for CS5 are those NVIDIA cards which cannot use MPE's GPU acceleration mode (either due to the lack of CUDA or an insufficient amount of graphics RAM) because they perform even slower than ATi cards in software-only mode. Last edited by Randall Leong; August 5th, 2010 at 07:13 PM. |
#19 |
Long time lurker, first time poster.
Currently have the Gigabyte 460 1GB model. Able to get it on sale for $199 recently. Not too loud at all. Seems to be the best value per performance card that nvidia has produced in a while. Works great with MPE and the hack. Overall, probably the best card performance for price that I have owned in a long time. |
#20 |
Currently MPE is still in it's infancy and CUDA Toolkit 3.1 has just appeared.
What does that mean? First of all that at this moment in time there is no performance difference noticeable between a GTX-285 and a GTX-480, tested on the same system. This despite more than double the cores and double the width of the memory bus of the 480 over the 285. At this moment the conclusion may be that the 460 is the most attractively priced MPE card with the same performance as the 480. However, it is to be expected that when MPE get's more mature, it will use available cores more efficiently. Just like the threading on certain processes in CS5 that is far from optimal, causing much more latency in the communication between CPU - RAM - GPU - VRAM and back, especially on hexa cores. Threading is a major factor for performance gains, both in the CPU and in the GPU. Therefore I expect that in time the 470 or 480 will be a much better choice than the 460. |
#21 |
Harm,
I hope you are right about future optimizations improving the performance of these video cards, but do the 470/480 offer any other meaningful architectural advantages over the 460 beyond the "processor core" count? I know the memory bandwidth on the 480 is much higher Do the benchmarks show memory size/bandwidth (beyond the previously discussed limit) really matter for performance? FWIW, here's a little info I gleaned off a simple search on Newegg: GTX 260 896MB: 216 cores $180 $0.83 per core GTX 285 1 GB: 240 cores $300 $1.25 per core GTX 460 1 GB: 336 cores $230 $0.68 per core GTX 470 1.2GB: 448 cores $350 $0.78 per core GTX 480 1.5GB: 480 cores $450 $0.94 per core |
#22 | |
On the other hand, some of the low-end GPUs have too slow of a graphics memory subsystem (read: too low of a memory bandwidth) to be of any good in MPE. Those cards which use 1GB of DDR2 memory showed no performance improvement (or even a performance drop) versus software-only mode. Hence, those bottom-of-the-line cards are not recommended for CS5 even if they have 2GB of DDR2 graphics RAM. As for the last sentence, it all boils down to the different optimizations in the different manufacturers' drivers. In my testing, ATi's drivers are actually significantly faster than NVIDIA's drivers in MPEG-2 SD encoding performance but moderately slower in H.264 HD encoding performance. |
#23 |
Randall,
Just today I have updated both the Interpreting Results page and the Background Information page, to give some more information about the differences between hardware and software MPE when encoding. It may help you understand what causes the differences between ATI and nVidia cards and MPE on/off results. However, keep in mind the maximum quality settings when using CUDA/MPE. PPBM5 Benchmark |
#24 |
Harm,
Can you point me to where it says that Maximum Quality is engaged when using hardware acceleration because MRQ is not engaged by default or in PPBM5. Also, using MRQ greatly increases quality as well as rendering time, but it is worth every extra second of rendering time. |
#25 |
So I went with the 480 in hopes there will be future enhancements down the road. I swapped the new 480 into my Supermicro Xeon system and re-ran the PPBM5 rendering test only. I did not run the encoding tests as I assumed these would be unaffected by the new card.
With MPE SW acceleration only the rendering time was 199 secs, virtually the same as with my older ATI card. With GPU Acceleration turned on after the hack, the rendering time was 20 secs – a tenfold increase. Remarkable. Good God, that 480 is a huge beast, with what looks like chrome exhaust pipes wrapping around the body and a fan that extends over the CPU heat sinks (or something – it barely fits into my huge Supermicro case). It takes THREE 6-pin power supply cables, as the only unused 8-pin connector from my PSU was the wrong type. Fortunately EVGA included an 8-pin to Two 6-pin adapter cable, and all fits and seems to be working well. At least there is no apparent smoke that I can see or smell. By the way, a simpler form of the hack is to simply find the txt file as directed, and replace the “285” in “GeForce GTX 285” with “XXX”, where XXX is your model number. Reduces the chance of typos this way and eliminates the need to go into that other exe file and all that nonsense. I suppose you could do the same with the Quadro card numbers as well. We observed from other posts that even a capitalization error renders the hack ineffective.
"It can only be attributable to human error... This sort of thing has cropped up before, and it has always been due to human error." |
#26 | |
Also, I found differences between the 257.21 and the 258.96 drivers in my testing with the 470. The 257.21 drivers were a bit faster in encoding but the encodes suffered in quality, with black or green squares ruining the encodes through the 257.21s. And of course the difference between MPE in software-only mode and MPE in GPU-accelerated mode with the 470 is roughly ten-fold. But while the 470 is a great card for PPro CS5 use, it is not really needed there (though a system with a highly overclocked hexacore CPU would have benefitted from the 470 over the GTX 2## series GPUs). I could have gotten nearly the same level of performance by going as low as a 1GB GTS 250 (at least with my particular system's CPU). And had I continued to use my secondary system's Core 2 Quad Q9450 for CS5, I could have gotten away with even a 1GB DDR3 or GDDR5 version of the GT 240. Last edited by Randall Leong; August 16th, 2010 at 08:35 PM. |
#27 | ||
I posted this in another thread and thought it would add to the discussion here:
Here's an excerpt from David Knarr's well-written article: Quote:
A logical conclusion, if these statements are true, is that having more cores only provides marginal improvements. Elsewhere in his article, he says: Quote:
It would be very exciting if a GT240 provides close to the same performance as a GTX480 when it comes to Mercury Playback. I don't play games and am just interested in Premiere CS5 performance. Also, I believe the GT2xx series is compatible with OSX, whereas there are no Fermi (4xx series) drivers (yet) for OSX. Thanks in advance! |
#28 | |
#29 |
But what about the ram's Bit? Both of the GT 240s only use 128-bit whereas other cards go up to 448-bit with DDR3 ram, and this increases bandwidth to similar, if not, greater than DDR5/128-bit.
#30 |
This is because in my testing MPE barely takes full advantage of even 128-bit graphics memory, let alone 448-bit.
