Nvidia hack and 9300m GPU? at DVinfo.net
Adobe Creative Suite
Old June 22nd, 2010, 11:34 AM   #1
Will the hack to allow other Nvidia GPU's work with this card?
Brian Tori is offline   Reply With Quote
Old June 22nd, 2010, 11:36 AM   #2
Try it and you know it.
Old June 22nd, 2010, 02:10 PM   #3
Brian,
The 9300m only has 16 CUDA cores, similar to the 9400GT video card that I tested.
I would be interested in seeing if you saw a difference between the MPE running in software mode or hadware mode using the 16 CUDA cores.
David Knarr is offline   Reply With Quote
Old June 22nd, 2010, 06:41 PM   #4
Once I get CS5 installed, I'll try it and post results if it works.
Old June 24th, 2010, 08:51 AM   #5
No go. Apparently with only 256mb of video RAM the hack does not work with my card.
Old June 24th, 2010, 10:00 AM   #6
You need at least 796 megs of video ram (765 is the min.)
