How to make Premiere CS5 work with GTX 295 and possibly all 200 GPUs - Page 6 at DVinfo.net
Adobe Creative Suite
Old May 7th, 2010, 01:05 PM   #76
Originally Posted by Bo Skelmose View Post
Finally got my GTX 470 and today my CS5. Trying to make it work I try to change cuda_supported_cards.txt but when I try to save it I do not have the permission. I am logged in as an administrator and I have tried to unclick the write protection in the premiere folder and on the file - but no luck - HELP
I think I had that, make sure PP isnt running and you close all the Adobe Processes in task manager.
David Dwyer is offline   Reply With Quote
Old May 7th, 2010, 01:08 PM   #77
If anyone is having problems I've added a few cards into my text file and attached it. Just save it to the directory below and overwrite your file in there.
c:\Program Files\Adobe\Adobe Premiere Pro CS5\
File Type: txt cuda_supported_cards.txt (192 Bytes, 1295 views)
Old May 7th, 2010, 01:09 PM   #78
Great - Thanks - it works - IT is Fantastic how premiere handel video now - Cant wait to start editing projects in CS5....
Bo Skelmose is offline   Reply With Quote
Old May 7th, 2010, 01:10 PM   #79
Please let us know the results MPE vs Software as I'm about to purchase a GTX 470 tomorrow and would be keen to know your thoughts.
Old May 7th, 2010, 01:47 PM   #80
Dont have much time testing today but 1 hour and 6 minutes DVCPro HD exported to quicktime DV took 12 minuttes with hardware activated and 21 minuttes with "only software" Tried editing with more layers with colourcorrection and other accelerated effects and no accelerated effects - and no lost frames (hardware)
Old May 7th, 2010, 01:50 PM   #81
What power supply are you using Bo?
Old May 8th, 2010, 02:10 AM   #82
I'll beat Bo on this, I've got Antec Earthwatts 500; I thought it will not be enough but it's running smooth and stable.
A note about noise/heat. the GPU runs at 80c most of the time, and the fan noise doesn't really become audible until 56%, anything below this setting it's quiet.
Ezzat El Halabi is offline   Reply With Quote
Old May 8th, 2010, 02:14 AM   #83
Yeah all the reports say a min of 550w and 38amps on the 12volt line
Old May 8th, 2010, 06:43 AM   #84
Keep in mind that is the minimum requirement. If you are running a bunch of other devices, multiple HDs or optical drives, they all draw power. I personally went with a 900watt power supply to be safe.
Brant Gajda is offline   Reply With Quote
Old May 8th, 2010, 10:44 AM   #85
550W PSU is sufficient if you do not install hard disks, DVD/BR burner and use only one stick of memory and do not overclock your system, do not use USB ports, etc., and do not plan to use it longer than one year.
If that is not the case do not consider anything below 750 W.
Look here, and calculate with a 100% load and 30% capacitor aging, then add around 15% to the estimated wattage: eXtreme Outer Vision - eXtreme tools for computer enthusiasts
Old May 8th, 2010, 12:34 PM   #86
I am in the process of building a new dual boot box (Mac + Windows) -w- a GTX 285 and I went with a 1200 watt BFG power supply.
Bill Sepaniak is offline   Reply With Quote
Old May 8th, 2010, 11:41 PM   #87
I have an 1000 watt corsair with mountable power cables. I made it a kind of standard in my computers as I often put a lot of cards, fans and harddrives in it too. Dont want to go down on the power side as it is not expensive. Again Thanks Adobe.....
Old May 10th, 2010, 08:54 AM   #88
Originally Posted by Martin Guitar View Post
As long as you have enough video memory your 200 cards should all be as good as a 285.
Martin, I can confirm at least the GTX280 rocks and rolls with this hack. Just playing with the CS5 trial version and I'm sold!
Bob Krieger is offline   Reply With Quote
Old May 10th, 2010, 09:57 AM   #89
Hackintosh
It works on my hackintosh with GTX 275 1792 MB ram. I did the same way windows users did.
Maryus Ionel is offline   Reply With Quote
Old May 10th, 2010, 12:56 PM   #90
perfectly working with my good old GTX260 (192sp, 896MB memory). i was even able to flawlessly edit xdcam video in fullhd on dual core cpu. had to upgrade to quad anyways. damned AVCHD...
OT: is anyone else having trouble playing same AVCHD clip in two layers above, top resized to be smaller? it works fine if its two different clips, if the same clips are in the same position, but once you move the so they are not in sync, it wont play more than few frames, cpu load is not reaching 100% by far. hope its just a bug
Petr Bartak is offline   Reply
