#46 |
Command prompt
Please advise, I can not figure out how to get the command prompt thing to work. It keeps telling me "program in not recognized as an internal or external command, operable program or batch file." Any advice would be appreciated.
#47 | |
Download and run the the following: http://www.northern-loop.tv/Video/gpu.cmd Its just a basic batch file that runs the GPUsniffer in the default CS5 directory. Hope it helps, David |
#48 |
If you are on windows 7 here are the steps. For XP it's the same but instead of search field it's the RUN menu.
1. Click the Start Menu Button 2. In the search field (Search programs and files) type: cmd 3. You will see a black icon at the very top called "cmd", click on that. 4. Go to your Premiere CS5 installation folder and drag the file "Gpusniffer.exe" into that "cmd" window(Black window with white text in it.) 5. Press enter to run the Gpusniffer program. |
#49 |
Thanks guys, I think I got it! Although in the playback window it looks like I am getting a 4:3 aspect ratio
#50 |
Curious, should I even bother trying this with my card?
ASUS ENGT240/DI/1GD3/A GeForce GT 240 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready Video Card I'm running Win 7 64bit, i5 860, 12Gb DDR3 RAM, single monitor. Thanks, Roy |
#51 |
Yes give it a go as its only a 2 min to fix. You have 96 Cuda cores in that card, every bit helps!
#52 |
David, I assume the fix is to just change the cuda_supported_cards.txt file back and save it. And change the Nvidia field "multi-display/mixed-GPU acceleration back. I wasn't able to get the 3d setting to add Abobe Premiere Pro CS5. Maybe that was the problem. BTW, I have CS4 and I downloaded the trial of CS5 because I am waiting for it to ship from Videoguys.
#53 |
Just changing the text file will be enough for a single monitor. Open Pr and switch on MPE and test
#54 |
Do you think we will get faster MPE performance with 1 monitor VS 2?
#55 |
#56 | |
Hopefully after my work day ends, I'll do some more testing with non-accelerated effects. |
#57 | |
If you could do some export times that would be great MPE vs Not |
#58 |
Effects were: Gaussian Blur (I believe), Noise (cranked just about all the way up), Fast Color Correction, B&W, Levels (I believe), and one other.
I'll confirm tonight. Also, I'm using Cineform AVI files of my 5D Mark II, so that "might" be why it's still showing yellow. |
#59 |
Matrox compress HD
Anyone hear about this? It seems with new driver that it aids in time line playback as well as rendering. If thats true it may be better for me VS a new video card.
#60 |
Brant, I'm considering getting the 480series since right now it has most CUDA cores (FERMI) and Adobe is planning to officially support 400 series GTX cards later this year. But I've heard that the card runs hot but I'm concerned with the noise level of the card. How loud is it? At idle and at load?
