My Unofficial CS5 Premiere vs CS4 Premiere Export #s - Page 2 at DVinfo.net
Adobe Creative Suite
Old May 7th, 2010, 11:41 AM   #16
Brant that would be great - I'm sitting here looking for a GTX 470..
David Dwyer is offline   Reply With Quote
Old May 7th, 2010, 11:51 AM   #17
Here is my 2 clips
CFHD
General
Complete name : D:\Video Capture files\HD Footage\VMAX Judgement Day\Exports\Doug Cineform 1440.avi
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 1.68 GiB
Duration : 3mn 26s
Overall bit rate : 70.1 Mbps
Recorded date : 2010-05-07T17:06:29.00207+01:00
Writing application : Adobe Media Encoder CS4
Video
Format : CineForm HD
Codec ID : CFHD
Codec ID/Info : CineForm 10-bit Visually Perfect HD (Wavelet)
Duration : 3mn 26s
Bit rate : 68.5 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Bits/(Pixel*Frame) : 1.763
Stream size : 1.64 GiB (98%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Unsigned
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 3mn 26s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 37.8 MiB (2%)
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 80 ms
Exporting WMV file that will take 4 hours!
General
Complete name : C:\Video Capture Files\Sequence 01.wmv
Format : Windows Media
File size : 5.47 KiB
Overall bit rate mode : Variable
Maximum Overall bit rate : 10.5 Mbps
Encoded date : UTC 2010-05-07 17:46:12.276
Video
Format : VC-1
Format profile : MP
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9 - Professional
Bit rate mode : Variable
Bit rate : 8 000 Kbps
Width : 1 920 pixels
Display aspect ratio : 16:9
Resolution : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.154
Language : English (GB)
Audio
Format : WMA
Format profile : Pro
Codec ID : 162
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 10 Professional - 440 kbps, 44 kHz, 2 channel 24 bit 1-pass CBR
Bit rate : 440 Kbps
Sampling rate : 44.1 KHz
Resolution : 24 bits
If MPE speeds this up I'm buying a new GFX now!!
Old May 7th, 2010, 12:38 PM   #18
David,
I may need your help since I never really use WMV to encode files. Here is what I setup in my export settings and you can let me know what I did wrong/right:
Export Settings:
Windows Media
Preset Custom
Video:
Codec: WMV 9 Professional
Encoding Passes: 1
Bitrate mode: Constant
Pixels: 1920x1080
Frame Rate: 29.97 (matches my footage)
Pixel Aspect Ratio: Square 1.0
Bitrate Settings
Max Bitrate: 10,000kbps (10Mbps)
Image Quality 100
Audio Same as your listings.
Total output time was 11mins and 2 secs. Video quality looks absolutely perfect, but wasn't sure if my settings match up with yours.
Brant Gajda is offline   Reply With Quote
Old May 7th, 2010, 12:55 PM   #19
11mins! hah and there is me with my 4 hours!.
Only difference is my source CFHD file is 1440*1080 1.33PAR and I'm outputting to 1920*1080 1.PAR and I'm doing 2 passes instead of 1.
Now I wonder if I can get a GTX 470 tomorrow.
Old May 7th, 2010, 12:58 PM   #20
Was the 4hrs through CS4 Adobe Media Encoder? If so, that probably explains the majority of the problem.
Old May 7th, 2010, 01:02 PM   #21
Yep. Edited a few clips together then exported them to a master CFHD file.
Export that file and it took 3 mins to create the 1.7GB CFHD file. Added this file back into CS4 and exported to WMV file. So there isnt any effects it rendering its just compressing and resizing the clip.
Old May 7th, 2010, 09:30 PM   #22
Originally Posted by Brant Gajda View Post
Any particular codec used on the SD material?
In my tests I exported to the Lagarith Lossless Codec in the .AVI wrapper. But many other modern codecs could be used in the test as long as they have exactly the same export settings.
I've heard from various sources that the HD to SD quality in CS5 was improved over previous versions. But in my tests the CS5 versions were noticeably softer than the CS4 versions using the exact same settings.
Mitch Hunt is offline   Reply
