Windows 7 home premium issue?
Hi, does anyone know if there is a compatibility issue with Premiere CS4 and Windows 7 home premium? I keep getting "Error 1603. Fatal error" during installation.
I can't answer the question directly, but here as an Adobe page on Win 7:
Installing and using Windows 7 with Adobe applications
Pete Bauer The most beautiful thing we can experience is the mysterious. It is the source of all true art and science. Albert Einstein Trying to solve a DV mystery? You may find the answer behind the SEARCH function ... or be able to join a discussion already in progress! |
Windows 7 64bit pro, ultimate or home??
Since we're on the subject, i'm purchasing Windows 7 tonight or tomorrow...
I'm under the impression, that the PRO version might be best suited for the CS4 suite.. Does anybody want to chime in, as to which Windows 7 64 bit is preffered? Thanx.. |
I've run CS4 under both Home Premium and Professional, both 64 bit. I don't know of any Windows features CS4 would need beyond Home Premium, but the features in the higher versions won't harm CS4.
#5 |
I know Premium is limited to 16GB of ram and both Pro & Ultimate are far higher.
And I think Premium is limited to one CPU whereas I know Pro/Ultimate are limited to 2. Some video gear needs Pro as a minimum (such as some Matrox products). |
#6 |
Steve,
Win7 Pro uses all cores. In my case all 8 of them. I believe the current limit is 16 cores. This picture shows all cores used during encoding with AME. Sidenote: Rendering the timeline does not appear to be using HT, so previews only use 4 cores on my system, but that may be caused by the fact that my CPU usage during rendering never was more than 12%. During encoding it was far higher. Sorry if I misunderstood you. Reading your message again it looks like you are talking about physical CPU's, not cores. Last edited by Harm Millaard; March 7th, 2010 at 07:09 AM. |
