corecting image which out of focus at DVinfo.net
Adobe Creative Suite
Old February 19th, 2010, 06:12 AM   #1
Hello,
Can anyone tell me if it is possible to repair image which is out of focus?
I am using CS4 collection.
Thank you, Bye
Primoz Lazar is offline   Reply With Quote
Old February 19th, 2010, 06:23 AM   #2
Hi Primoz,
Is this a still image or video?.
With video and assuming you have tried the array of sharpening tools you could try scaling. A bit like a photo you could scale the image down and applying a sharpening filter.
Open the segment in Photoshop CS4. Convert the layer to a 'smart layer' scale the video down to 720 or SD sizes and add sharpen or USM to taste. Then render back out.
If you had 1080 file and scaled to 720 the image would hold up better to sharpening.
This only works if the focus is just off. If the detail has gone its gone.
Have you an example frame you could post?
James Miller is offline   Reply With Quote
Old February 19th, 2010, 06:54 AM   #3
Hello,
I have video image, What exactly should i do ? I can post image later cause I am not at home now :)
Old February 19th, 2010, 08:21 AM   #4
Best results and easiest is Reshoot.
Old February 19th, 2010, 10:48 AM   #5
hehe tanks ;) i know.
Old February 19th, 2010, 12:14 PM   #6
Originally Posted by Primoz Lazar View Post
Hello,
Hi Primoz, What resolution is your footage?
Old February 19th, 2010, 01:15 PM   #7
Hello,
It is HDV: 1080 x 1440
Old February 19th, 2010, 04:45 PM   #8
Ok thanks, can't really judge until I can see the footage or a few grabs.
BR, James
Old February 19th, 2010, 06:10 PM   #9
in CS can you apply the "smart Sharpen" filter properly set, is the one filter in photoshop that can do something for a minor blurring. Ask it to remove Gausian blur, and adjust the radius perfectally.
proper application of an "unsharp mask" with the right settings (again) would be a possiblity too, with the right threshold you can keep from sharpening the noise TOO.
and In noise removal the "reduce noise" can mix up the sharpeneing with some noise filtering , if the picture is soft AND still has grain noise that would be undesirable to sharpen so you can in one pass, remove some noise, then sharpen what is left.
----------------sig-----------------
Re-learning everything all over again, one more time.
Marty Welk is offline   Reply With Quote
Old February 20th, 2010, 04:53 PM   #10
If it's video of a person (or several people), concentrate very carefully on their eyes and sometimes you don't have to sweat the rest. That's where your viewers will notice it the most.
AE can sometimes do wonders with slightly out-of-focus material.
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply With Quote
Old March 7th, 2010, 04:22 PM   #11
Copy footage from track 1 and paste it into track 2: superimpose.
Apply Sharpen to track 2 and set it to about 30.
Lower Opacity between 50 an 70.
In worst cases you might want to try Convolution Kernel Sharpen in the same way as described above.
Ann Bens is offline   Reply
