best compression/render settings at DVinfo.net
Adobe Creative Suite
Old January 26th, 2010, 12:23 AM   #1
want to know if you can share your ideas on how best to get the best quality on my ex3 project in after effects when am about to render.settings that wont create any loss in resolution.shot HQ and might probably want to have final output in dv but still gettin a lossless resolution.am sending final output to tv stations here in nigeria.thx
x
Olabode Lawal is offline   Reply With Quote
Old January 26th, 2010, 03:40 AM   #2
I have told you before:
DV is 720 x 576 resolution. Nothing else (at least for PAL).
EX (HQ) is 1920 x 1080 resolution with square pixels.
If you do not want resolution loss, your only options are to use a codec that supports 1920 x 1080 resolution. H.264-BR or MPEG2-BR are two options that come to mind.
Old January 26th, 2010, 08:17 AM   #3
thx a lot but i also want to let you know if it can be transfered to a mini dv tape for distribution because that is what tv stations here require to broadcast.i shoot music videos majorly and a little commercials.can you give me a brief setting on how the output module will be like rendering with these codecs.thx
