HV20 and Premiere CS4
Hi
Trying this forum as I didn't get any response from the Canon HVxx forum: Just bought an used HV20 to have as second cam to my XH-A1. I imported some clips yesterday into Premiere Pro CS4 with following results: - Using HV20 25PF mode and importing footage into PPro CS4 on a 1080i/25P sequence a red line above the clips shows that some rendering has to be done. - Importing 25F clips from/filmed with my XH-A1 to the same sequence does not generate these render lines. - If I import HV20 25PF clips into a 1080i/50i sequence it does not generate render lines. - If I use the HV20 to capture 1080i/25F tapes filmed with the XH-A1 no render is necessary. Question: Do I have to treat 25PF clips from HV20 in another way than 25F clips from an XH-A1? (I hope this is the right forum for this question) Regards, /Bo |
