Recommended output format for old 4:3 footage at DVinfo.net
Adobe Creative Suite
Old January 2nd, 2010, 11:40 AM   #1
Hi All, (Newbie here)
Have capture some very old footage footage which is in standard 4:3 format. I have edited and almost done, but what format ratio and settings would be best to render this video too?
Are there any rules I should be following for all the new TV formats etc. (this project for DVD only)
Look forward to your responses.
Many thanks
Mark van der Byl is offline   Reply With Quote
Old January 3rd, 2010, 06:25 AM   #2
4x3 MPEG2-DVD.
Old January 4th, 2010, 03:30 AM   #3
You have a choice.... do you intend to watch it on a widescreen set?
You could have it as a 4x3 format on a 16;9 project, having black bars either side... this is the industry standard.
Or you could pan and scan or you could zoom in and re render it to 4x3....
Ben
Ben Longden is offline   Reply With Quote
Old January 8th, 2010, 02:18 PM   #4
Actually there are NO choices as long as you want to preserve the quality - since we're talking about old footage, there is not much quality to start with.
So keep it 4x3. Going 16x9 you will loose quite a bit of resolution!
A correctly authored DVD will be correctly displayed even on a 16x9 HD screen.
Ervin Farkas
www.AtlantaLegalVideo.com
Old January 10th, 2010, 10:20 AM   #5
Harm, Ben, Ervin.
Thanks for your responses. Sounds like I should keep it as is, and look at it again when authoring the dvd.
Many thanks
Old January 11th, 2010, 12:13 AM   #6
That should have been the case--but when it comes to standalone DVD players, it seldom holds true. Many DVD players that I've used always stretched 4:3 videos (yes, even from DVDs with mixed 4:3 and 16:9 content) to fill 16:9 screens no matter what I did (and even as 4:3 content is stretched, 16:9 content is displayed correctly)--to the point that I had to manually set the TV's display mode to 4:3 whenever I view 4:3 material (but then, 16:9 content would get squashed into the 4:3 frame). And, when I set those same DVD players for a 4:3 set, the 4:3 images still get stretched while 16:9 content gets both letterboxed and stretched. This is because few standard-definition DVD players correctly recognize the embedded flags for different aspect ratios; after all, standard-definition DVD was originally conceived at a time when all TV displays had a 4:3 aspect ratio. (By comparison, most Blu-Ray players do correctly recognize the DVD aspect ratio flags.) As a result, mixing 4:3 and 16:9 material onto a single DVD can become needlessly frustrating.
Randall Leong is offline   Reply With Quote
Old February 1st, 2010, 04:09 PM   #7
Something I have only noticed now this footage has gone to big screen is that there is a green bar down right hand side. Only on some clips? Have I missed something again with this old 4:3 footage?
Old March 16th, 2010, 06:10 PM   #8
I am doing pretty much the same thing. I am cutting old 4:3 footage into smaller clips for the web. The problem I have is the quality of the footage is not that great, but when I render from premier it looks even worse. Is there a way to render these clips without losing any quality, i am not to concerned with size of the file?
Brian
Brian Jeffries is offline   Reply
