Frame Export in Premiere CS4 at DVinfo.net
Adobe Creative Suite
Old November 18th, 2009, 05:20 PM   #1
I have read somewhere that single frame export to bitmap or jpeg files is not supported in Premiere CS4 as it is in CS3. Is this true?
If so what workflow do people use to get around this?
Steve Pesenti is offline   Reply With Quote
Old November 18th, 2009, 05:45 PM   #2
Yeah you can export frames now.
David Dwyer is offline   Reply With Quote
Old November 18th, 2009, 09:03 PM   #3
Windows Bitmap, GIF and Tiff are supported, they are in AME. There isn't a Jpeg option. / Battle Vaughan
Old November 18th, 2009, 11:09 PM   #4
You have to assign the Work Area to a single frame..... then fire up the good old Media Encoder. It makes you wonder if there is an Adobe engineer who has ever edited anything.
I hear the next version is going to be called CS3.
Marty Baggen is offline   Reply With Quote
Old November 19th, 2009, 02:20 PM   #5
At least in CS4, all you have to do is put your cti on the frame you want to export, you don't have to change the work area at all.../ BV
