Premiere Pro CS4 Benchmark - Page 4 at DVinfo.net
Adobe Creative Suite
Old June 7th, 2010, 03:46 AM   #46
David,
What you experienced here is something a number of people have seen and I have no explanation for it.
What we see when people run the PPBM4 benchmark test on the same hardware with CS4 and CS5 they find that the AVI test takes about twice as long under CS5 with MPE turned off and nearly 4 times as long when MPE is turned on.
For example my results:
CS4: 1.4
CS5: 2.9 with MPE off
CS5: 5.4 with MPE on
If anybody has a logical explanation, I would like to hear is.
Old June 7th, 2010, 03:51 AM   #47
Originally Posted by Harm Millaard View Post
David,
CS4: 1.4
Its the GFX card that is being clocked down.
Download CPU-Z and you will see the speed differences.
Mine is flicking from
CORE: 300mhz
SHADERS: 600mhz
MEM: 100mhz
to:
633mhz
1404mhz
1131mhz
Pretty sure is will cause the slow lag
David Dwyer is offline   Reply With Quote
Old June 7th, 2010, 05:22 AM   #48
David,
This does not explain the deterioration from 1.4 to 2.9 with an ATI card, just by the move from CS4 to CS5.
CPU-Z does not show any changes in Core, Shaders or Memory, they remain stable at 721, 1442 and 1880 MHz. Is there any way to allow for real time updates to the display of CPU-Z, or are you talking about GPU-Z?
Old June 7th, 2010, 05:39 AM   #49
Not sure about the ATI card setup.
Here is what CPUZ is telling me - cpuz.png is the standard use with no 3d stressing. 01 is with it stressed a little and you can see the clock speed has gone to full speed.
And 02 is the meant to turn off this down clocking.
Old June 7th, 2010, 05:44 AM   #50
David,
GPU Z causes the card to run at full speed. Have CPU and GPU Z open and close GPUZ and watch the rates return to lower clockl?
Old June 7th, 2010, 05:54 AM   #51
Well as a little test I ran the PPBM4 while GPUZ was open forcing the card to run at full speed - Confirmed in CPUZ
MPE on with GPUZ Open:
21.9, secs Total Benchmark Time
8, secs AVI Encoding Time
7.9, secs MPEG Elapsed Time
6, secs Rendering Time
MPE without
23.1, secs Total Benchmark Time
8.1, secs AVI Encoding Time
8, secs MPEG Elapsed Time
7, secs Rendering Time
So maybe the down clocking of the GPU isnt effecting it and its something else?
Old June 7th, 2010, 06:21 AM   #52
Makes no difference here.
Old June 7th, 2010, 06:36 AM   #53
Mine changes but doesnt seem to make any difference anyways.
Hmm
