Exporting with Premiere Pro 1.5 at DVinfo.net
Adobe Creative Suite
Old December 1st, 2004, 04:27 PM   #1
Ok, so i tried out the 30 day trial. And i am having a problem exporting the final project trought Preimer. Importing everything worked great, but for some reason it wont send it back to the camera what should my settings be. Thankt -fernando
Fernando Maldonado is offline   Reply With Quote
Old December 1st, 2004, 07:32 PM   #2
Your project used a DV preset when you created it? And you had no problem capturing the footage?
PAL or NTSC?
And your camcorder allows DV In? Not all PAL camcorders do.
Steven Gotz is offline   Reply With Quote
Old December 2nd, 2004, 02:47 PM   #3
Fernado,
Please provide more info.
What steps are you currently taking, and as Steven has pointed out what settings are you using?
If you can set playback to play through you DV camera then you should not have any problems exporting to tape (In theory). You can set DV playback through Premiere settings.
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline   Reply With Quote
Old December 2nd, 2004, 03:16 PM   #4
I imported with a pd-150, and tried to export with the same camera. I also tried my xl1s but still didnt work. I checked my settings and have playback set for dv and monitor same with audio. -thanks
Old December 2nd, 2004, 03:18 PM   #5
oh yeah and its ntsc
Old December 2nd, 2004, 04:13 PM   #6
Stupid question I know, but you are in the VTR mode right? Not on record?
Old December 3rd, 2004, 03:37 AM   #7
So , with DV playback set do youi see the pictures/ clips on your timeline through your PD150? If so that would mean that DV in is working.
If the above is working you could simply press the record button on your PD150 and then play the timeline (timeline will need to be rendered), This will then crash record the timeline to your tape. You'll have to stop the record manually
What settings are you using in the export to tape option?
Ed Smith
Hampshire, UK
Old December 4th, 2004, 12:31 PM   #8
No i dont get playback trought it, but i do lose sound trought my speakers. When i unpluge the camera i get my sound back. yeah im in vtr.
Old December 5th, 2004, 07:47 PM   #9
Could it be the trial version won't allow exporting?
Bob Schneider is offline   Reply With Quote
Old December 6th, 2004, 04:30 PM   #10
thats what i was think... but thanks for helping anyways guys. -fernando
Old December 7th, 2004, 12:59 PM   #11
I thought that you could use all the feaatures in the Premiere Pro trial, but it will stop working after 30days?
Then again it could be feasible that they disabled this feature...
Ed Smith
Hampshire, UK
Old December 8th, 2004, 03:44 PM   #12
You have to enable "DV in" in the menus of the PD150. I don't have my camera with me to see exactly waht to do but I had the same problem until I enabled this in one of the menus.
Sony Fan Boy! Sony AX100, VG20, RX10, A6000, CX760 and a GoPro 4
Dan Tolbertson is offline   Reply With Quote
Old December 15th, 2004, 07:24 AM   #13
Also, under the setting for the project, check to see if the dv is enable and the audio concern is when it's going to the camcorder, it is doing playback through it so your speaker won't play sound. You can change that setting there
Assuming you are using Premiere Pro 1.5 Trial
Branding for visual creation. Www.mdifilm.com
Johnny Wu is offline   Reply With Quote
Old April 23rd, 2005, 01:16 PM   #14
For anyone interested, A Joker's Card is finished and it's edited entirely with Premiere Pro and color corrected.
www.mdifilm.com/joker
Johnny Wu
