Adobe Premiere discussions from 2003 - Page 7 at DVinfo.net
Adobe Creative Suite
Old March 7th, 2003, 04:29 AM   #91
Also make sure that there is extra footage at the end of first shot and beginning of second shot when using crossfade. Otherwise Premiere will be forced to repeat some footage, and this can look like flicker.
In short: Set the out point in first shot at least a second before the shot ends, and the in point in second shot at least a second into the shot.
That way Premiere will have 2 seconds of overlap to work with.
Hans Henrik
Hans Henrik Bang is offline
Old March 7th, 2003, 05:30 AM   #92
Newbie question re: Premiere Flicker
You did specifically mention cross dissolve so this probably isn't your problem but some months back I saw this result when using the additive dissolve, one above cross (in P6). I gave up using it for that reason.
David Hurdon is offline
Old March 8th, 2003, 05:05 PM   #93
automatic scene detection in Premiere 6.5?
It appears that Premiere 6.5 does NOT have automatic scene detection for capturing. Is that right?
Is there a plugin available that would add that function?
Thanks.
Steve
Steve Clodfelter is offline
Old March 8th, 2003, 05:26 PM   #94
Premiere does not gave automatic scene detection. There is a stand-alone capture program called Scenalyser (www.scenalyser.com) that captures and splits into scenes. There used to be a freeware version for just splitting captured files but I couldn't find that on the Scenalyser page anymore. You can download a demo of Scenalyser and see if you like it.
Hans
Hans van Turnhout is offline
Old March 8th, 2003, 06:36 PM   #95
Thanks, Hans.
In addition to Premiere 6.5, I have Pinnacle Studio 8.0 which does have automatic scene detection. I suppose I could capture in Studio then import the clips into Premiere for editing. Do you know any reason why that wouldn't work?
Steve
Old March 8th, 2003, 06:56 PM   #96
That might work. Both programs capture in AVI but I'd be willing to guess Pinnacle captures at a lower resolution. You could still import the clips into Premiere but they would be of lesser quality if this is true.
If you can change any settings in Pinnacle, get them as close as possible to Premiere's capture settings (720x480 resolution, 48kHz audio, etc) and you will have no problem at all.
alextaylor.org
Alex Taylor is offline
Old March 11th, 2003, 01:09 PM   #97
Adobe Premiere User Forums
Hello!
Is anyone aware of any Adobe Premiere user forums (other than this one) where I may go and pose questions on how to do a particular effect?
Thanks a bunch
Jean King
Jean King is offline
Old March 11th, 2003, 09:07 PM   #98
You might also check out www.wrigleyvideo.com and http://www.stevengotz.com/premiere.htm
Steve
Old March 12th, 2003, 06:52 AM   #99
Adobe has interesting forums for all it's products...After Effects, Premiere, Photoshop. Some good FAQs, too.
http://www.adobeforums.com
Robert Bobson is offline
Old March 13th, 2003, 08:30 AM   #100
Adobe Premiere 6.5 ability questions
Hi Everyone,
I am still editing on 6.0...and I have a question about 6.5.
You might be able to do this in 6.0, and tell me if you can:
I want to add 2 different video clips running as smaller windows on the frame...
Also can you scale in size the video clips??
Or can you put in a picture and scale in size the image an dmove it around?
jay
Jay Reilly
Oceanside, CA
jay@jayreilly.com
Jay Reilly is offline
Old March 14th, 2003, 06:13 AM   #101
If I think what you are trying to do is basically have multiple images on the same screen?
The answer is yes!!! and you don't need 6.5
All you need to do is place each video on a seperate video layer i.e 1a, 2, 3 etc (to add more video tracks, on the time line there is a little black arrow pointing to the right >, then select add video track)
Then apply a transform filter (found in the video effects folder) to each video. You can then effect its size, postion etc.
Then adjust the parameters.
Have a play around, and see how you go.
All the best,
Ed Smith
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline
Old March 15th, 2003, 05:18 AM   #102
RED Code Chef
You can read more about Scenalyzer at www.scenalyzer.com.
There is also a free version available that splits scenes up AFTER
you've capture them (this is what I use).
Download that here
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old March 17th, 2003, 07:10 PM   #103
Picture in Picture w/ Premiere
First and foremost, this site is awesome its helped me solve a lot of potential problems and pitfalls.
Question... can you do a picture in picture using Adobe Premeire 6.5? If you can, how do you do it?
Thanx
Walter McElroy, Jr. is offline
Old March 17th, 2003, 07:37 PM   #104
Check out this thread: http://www.dvinfo.net/conf/showthread.php?s=&threadid=6801&highlight=picture+in+picture
Steve
Old March 17th, 2003, 10:55 PM   #105
thanx a lot Steve, I appreciate it
