Adobe Premiere discussions from 2003 - Page 24 at DVinfo.net
Adobe Creative Suite
Old June 26th, 2003, 03:47 PM   #346
do you happen to have an external device plugged into the computer via the firewire?
Rob:D
Robert Poulton is offline
Old June 26th, 2003, 05:50 PM   #347
from what i heard
From what I understand the ez cleaner is only for final cut pro/apple. Is there another program that will help me get good internet broadcast quality that is compatiable with adobe premeir?
co-owner
www.gakcity.com
Michael McConnell is offline
Old June 26th, 2003, 08:45 PM   #348
I had a camera plugged in, but it is turned OFF. I also tried it un-plugged totally. No effect.
Andrew Ward
e-mail preferred: award@cisco.com
Andrew Ward is offline
Old June 26th, 2003, 11:22 PM   #349
There's a version that comes with and is installed with Premiere. Try FILE > EXPORT TIMELINE > SAVE FOR WEB. This should launch the cleaqner program and you can follow the wizard from there.
Adrian Douglas is offline
Old June 27th, 2003, 07:21 AM   #350
Re: Playback stutter
<<<-- Originally posted by James Emory : Try going to project settings and go into playback options. Once there, uncheck playback to camera/vtr and it should default to internal playback. -->>>
OK Tried this...no effect. Problem still remains.
Thanks... Any more suggestions?
Andrew Ward
Old June 28th, 2003, 02:11 PM   #351
Premiere problem
I have one very annoying problem with my Premiere. Sometimes when I'm open up a saved project it is destroyed, the timeline is empty and in the list of imported files (at the left usually) it's only files named "-1". Does anyone know what this is??
- jeha!
Jesper Hallen is offline
Old June 29th, 2003, 05:40 PM   #352
got it
Thanks for advice---all cleared up--found it
co-owner
www.gakcity.com
Old June 30th, 2003, 12:05 AM   #353
Scott,
Check this plugin out:
http://www.mykaskin.freeserve.co.uk/myksvideopages/plugins.html
I also had a problem using electronic 16:9 into Premiere. Using the right selection, you'll get letterbox 16:9 on a 4:3 NTSC screen.
Daniel Gee is offline
Old June 30th, 2003, 12:14 AM   #354
Daniel,
Thanks so much! That solves my problem!
Scott Silverman
Shining Star Digital Video Productions
Bay Area, CA
Scott Silverman is offline
Old June 30th, 2003, 09:19 AM   #355
I would wholeheartedly encourage you to use Avid or Vegas. Premier, I have found, is just terrible.
Peter Moore is offline
Old June 30th, 2003, 09:53 AM   #356
Hi Andrew.
I might be mistaken, but maybe the problems you are experiencing have more to do with your computer configuration than with Premiere. Maybe I'm telling you things you allready know, but you could check this:
Is your AV drive (where you store your video/audio files) at least ATA 100/7200rpm. Formated in one partition using NTFS. Currently not fragmented. A separate HDD (not the system HDD).
Have you tried uninstalling and installing the soundcard drivers.
My 2 cents. Hope it helps.
Good luck
Arnaldo
Arnaldo Paixao is offline
Old June 30th, 2003, 10:15 AM   #357
Have you got loads of effects/ transitions in your project, multi layers etc.
Does it do it with one simple clip on the timeline?
To export all your clips etc into a new project without Realtime preview:
Create a New project which is *not* realtime preview
Go file> Import> Import Project
Locate the project file, click OK
It will ask you where on the timeline you would like it placed. Tell it to start at beginning of timeline. Select OK
All done,
Hope this helps,
Ed
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline
Old June 30th, 2003, 10:19 AM   #358
Yeah, I have come to realize that. As soon as I save up, I will be buying Avid. Thanks!
Scott Silverman
Bay Area, CA
Old July 1st, 2003, 06:00 AM   #359
I'm not flogging any NLE over any other, but the pixel aspect ratio bug in Premiere 6 is well documented - and fixed in 6.5. For those, like myself, who haven't upgraded there is a workaround from www.jeremymoore.com that gets the job done. Once it's in place 16:9 works fine from then on.
David Hurdon
David Hurdon is offline
Old July 1st, 2003, 03:45 PM   #360
Short answer: Ditch Premiere- go with Vegas.
Seriously though, check your Premiere directory- look under the projects folder and you'll see you'll have multiple instances in which you saved your project...double click one of them from an earlier date. If the project loads fine immediatly hit CTRL+S to save.
If that doesn't work try deleting your preference file- maybe a preference file got corrupted. It happened to me once when I was finishing up a wedding....how do you think "I" felt when I couldn't even load my project without Premiere freezing...UGH!
Good luck- get back to us and let us know if it worked!
Glen Elliott is offline
