#1336 | |
/Roger |
#1337 |
I understand the overlay edit but what I mean is, I cannot find the covered clip at all! It's like the clip covering it had erased it. When I move the clip covering it, the clip I covered is no longer underneath where I placed it. Does that make sense?
Interesting, if true. And interesting anyway. |
#1338 | |
To avoid those situations in the future, always be careful when you drag media into the timeline so that you dont by mistake overlay material, use more video tracks, and never forget Ctrl+Z. Another way to avoid it is to lock video tracks. Lock tracks are not the best solution always though... /Roger |
#1339 |
Previewing through tv is not working, help!
Hi,
I've been tryin to preview the video from my timeline in premiere pro 1.5 through a tv but it dosen't seem to be working. When i captured the video it showed up fine on the tv but it won't show the video from the timeline. I've got the camera connected to the firewire card, and from the camera to the tv with um... the red yellow and white cord. I've also had a look under project-project settings-genral and tried to change it but i don't know, it dosen't want to work |
#1340 |
Hi Dylan,
Your camera has to be able to support dv to analogue pass-thru. If your camera does not then it won't work. If it does then you need to make sure you have DV Playback Settings set correctly. Go Project menu > Project settings> General Select Playback Settings Make sure that 'Play Video on DV Hardware' is ticked Make sure that in Real-Time Playback settings, 'Playback on DV hardware and Desktop' is selected That should be it! Hope this helps,
Ed Smith Hampshire, UK Good things come to those who wait My Skiing web www.Frostytour.co.uk For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors |
#1341 |
my camera has a av-dv out mode which can be turned on and off. its a canon mv630i (pal)
#1342 |
Volume control in adobe premier pro
Hey, I used to use all of the old school adobes and ever since I've started with adobe pro I noticed a huge thing missing. the volume control band thingies. Whats the deal with that? Fading and controlling audio levels used to be as easy as a few click and moving the rubber bands around - and now all there is is audio gain which causes terrible static whenever you use it to turn the volume up. Not only that, but the audio transitions are limited to two fairly garbage choices: constant power and constant gain [ if i'm not mistaken] am I missing something here? Is there something equivalent to the rubber band tools in older versions that I can use? please help!
#1343 |
Nic,
You can still adjust the audio volume in the timeline. However, the procedure is different in Premiere Pro, as the new pen tool is used to add and adjust keyframes. From the Premiere Pro help file: To edit a clip or track's audio levels in the Timeline window: 1. In the Timeline window, expand a track's view, if necessary, by clicking the expansion triangle next to the track name. 2. Click the Show Keyframes button, and choose Show Clip Volume or Show Track Volume from the menu that appears. 3. Use the pen tool to adjust the level uniformly (if keyframes have not been added) or to add or edit keyframes. |
#1344 |
PP has a great audio controls. The audio mixer allows you to follow through your timeline and use tools such as the write, read, latch and touch tools. With these all you need to do is adjust the volume control and it will do the same thing as the pen tool and keyframes. I never used any older versions of Premiere but for what I understand the audio in 1.5 surpasses all previous versions.
#1345 |
exporting project to dvd
is there any way you can export your entire project to dvd within premier? i know you can export directly to dvd but as far as i know you can only export one sequence. i need to be able to export 3 sequences to dvd without another program...is this possible?
get me another job. |
#1346 |
Things have slightly changed for my project. I am now doing a 30p DVD using Final Cut Studio- I have 60i footage and am thinking of shooting interview footage at 30p, and have several VHS cassettes to capture as well...
This may need to be moved over to the Final Cut thread since I'm no longer in Premiere... I needed the multi-cam editor, and Final Cut Studio just rocked my world- so I went all out and bought powermac g5 with FCS... Any pointers for workflow/problems with different footage qualities/progressive-interlaced problems etc...?? Thanks. ~jeff |
#1347 |
Is there any reason you need these sequences seperate? If not than just drop all of your sequences into one final sequence and export that.
#1348 |
Hi Dylan,
Make sure you are in VTR mode with AV pass-through set to DVin>Analogue(out). Provided you have told Premiere you wish to preview via firewire that really should be it. If it don't work then I suggest you borrow a friends camera to see if it does the same.... Cheers,
#1349 |
well i was hoping to have chapters.
#1350 |
Premiere HD Update/Slower Responsiveness
Has anybody else noticed that after he/she downloaded the Adobe HD Cineform upgrade (1.5.1 I think) from the Adobe website, the program takes longer to load non-HD projects?
