Adobe Premiere & Premiere Pro discussions from 2005 - Page 72 at DVinfo.net
Adobe Creative Suite
Old June 14th, 2005, 09:44 AM   #1066
What really made me take this seriously is the fact that Adobe actually admitted a flaw.
They didn't try to pass it off as a "feature enhancement" that needed to be "optimized" by this patch.
Must be very bad indeed.
Adam Kampia is offline
Old June 14th, 2005, 12:41 PM   #1067
Adobe After Effects: Pixelation Help!
Hey all,
I'm using Adobe After Effects 6.0 to do some "cloning," and it seems that whenever I see the video, there is a noticeable amount of pixelation. This is especially apparent when I add it to a Premiere timeline with other non-edited film. Is this normal for AE? The pixelation is small, and would be overlooked normally, but upon closer inspection it is easily seen. I'm doing cloning with raw .avi footage, and rendering in a lossless format, and in both the previews and the renders, the pixelation is there. I'm just wondering what the cause of the pixelation is and how I can fix it.
-Derek
Derek Brameyer is offline
Old June 14th, 2005, 05:34 PM   #1068
Are you rendering using "Draft" settings perhaps? (as opposed to "Best")
-Steve
Steven White is offline
Old June 15th, 2005, 10:48 AM   #1069
Missing Fancy Fonts
I just purchased PPro and was saddened to discover the lack of fancy fonts (most look the same). Specifically I'm looking for ones used on wedding titles that look like caligraphy/handwriting.
Is there software with additional fonts that can be added to the PPro title designer (or is Photoshop the answer), or am I missing something?
Thanks in advance.
Clarence Walker is offline
Old June 15th, 2005, 12:46 PM   #1070
Capt. Quirk
You can go online, and search for fonts... And that is where the fun really begins! Most programs will use fonts already installed, so just start looking at the millions of sites that have fonts, and download a few you like.
www.SmokeWagonLeather.us
K. Forman is offline
Old June 15th, 2005, 01:46 PM   #1071
Agreed! Take a look at http://www.dafont.com.
http://www.sareen.tv
Aanarav Sareen is offline
Old June 15th, 2005, 02:49 PM   #1072
Capt. Quirk
Should I warn him, he is about to enter "pop-up Hell"?
Old June 15th, 2005, 04:38 PM   #1073
Nope..."Best" Settings and "Lossless" Output (with audio added). The pixelation is bugging me now, and I don't know why it's happening. It's completely different with Premiere...looks like a normal .avi. But footage in AE looks terribly pixelated, even when I just import it into a composition, no effects. I just noticed it since I started working with Premiere. Anyone know what the problem is?
Old June 15th, 2005, 05:05 PM   #1074
Fonts
Thanks Aanarav and Keith:
Just loaded the fonts onto a CD here at work. Now I'm going to try to load them into Premiere at home.
Can't believe it's that simple. Will let know how it works tomorrow.
Clarence
Old June 15th, 2005, 08:31 PM   #1075
Originally Posted by Jimmy McKenzie
Understood with regard to scenealyzer and it's capabilities. The reason for not wishing to use a 3rd party capture is to maintain the integrity of the backup and long term storage of an offline file and use the source tape as a part of that equation.
I use Scenalyzer Live to capture dv footage and it is a GREAT- even superior- tool for making backups of source footage of my projects and for long term storage. As a matter of fact it has the ability to save the exact file names of your multiple captured dv avi clips so you can easily reconstitute your Premiere Pro projects as long as you save the project files and misc. graphics & titles along with the source footage on mini-dv.
Jim Gunn is offline
Old June 15th, 2005, 10:47 PM   #1076
I Agree
I agree with you Derek, I have noticed the same thing... but I thought it was just me. I still haven't figured it out, so any insight that someone can provide would be helpful.
My only thought is that I'm taking the 4:3 image I captured with an XL1s and upscaling it 135% to fit in the 16:9 frame then rendering it out. It might be the upscaling that's doing it. You wouldn't happen to be doing something similar would you? I haven't tried a straight 4:3 to 4:3 output to see if that pixelates too.
Webb Pickersgill
Bassline Digital, LLC
Webb Pickersgill is offline
Old June 16th, 2005, 12:32 AM   #1077
Is your footage interlaced? If so, check to see if your footage is only interpreted bottom field only. I think that's what it's called, I don't have AfterFX on this computer right now. In your composition, right click on your footage > interpret footage > fields (make sure it's showing both fields). Hope this helps a bit.
Kin Kwan is offline
Old June 16th, 2005, 07:26 AM   #1078
Yeah, if the footage is interlaced After Effects almost always separates the fields. You could be seeing a vertical resolution drop by nearly a factor of 2, especially if you're not doing the deinterlace with best quality settings.
Furthermore, blowing up a 4:3 XL1s frame to 16:9 anamorphic frame will only decrease image quality. You'd be better off to just letterbox the 4:3 image.
-Steve
Old June 16th, 2005, 02:01 PM   #1079
Which filter to use for color temperatur correction?
Hi there,
which filter in Adobe Premiere 6.5 (or PP 1.5) must I apply to a DV-video, when I want to correct the color temp. a little?
Say, I filmed with outdoor WB which is Celvin 5500°. When I now need a correction to say 4500° to 4800° - which is the correct filter to use to achieve this with best results and smallest quality loss / noise?
The Color Balance Filter HLS?
The Channel Mixer?
Or what?
With what settings, please?
BTW - I use it for night skys with fireworks. I have my correct WB in Canon and Sony cam stored but sometimes I need to adjust these a little, when they become a little to cold or warm...
Thanks in advance,
regards
Markus
Markus Klatt is offline
Old June 16th, 2005, 06:05 PM   #1080
Thanks a lot! That did it!
