Adobe Premiere & Premiere Pro discussions from 2005 - Page 67 at DVinfo.net
Adobe Creative Suite
Old June 3rd, 2005, 03:55 AM   #991
RED Code Chef
There are various extensions for mpeg-2, like:
- .mpg / .mpeg
- .m2v
- .m2t
.mpg / .mpeg usually are program streams, meaning they have both audio
and video in them. As Christopher explained the .m2v is just the video file
(since with DVD encoding the audio usually is a seperate file in AC3 form!)
and .m2t is a transport stream (kinda like a program stream).
The final form you have is .VOB on DVD. This is just an mpeg-2 transport
stream with a different extension for DVD. Nothing fancy about it.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old June 3rd, 2005, 07:04 AM   #992
Correction for clip shot with backlight on
Thanks Guys
After trying all you said looks like I'll have to reshoot the clip. Thanks again for your replies.
Harry
Harry Lender is offline
Old June 3rd, 2005, 11:06 AM   #993
Render Burnt In Timecode
It's ironic that something that has the word 'Pro' in it's title has the inability to render out burnt-in-timecode on the footage, but if you weren't aware there is a $20 plug in that seems to do exactly what most people want. I downloaded the trial and it renders the timecode in the clip and the timecode of where the clip is located on the project timeline. Think I'll be buying this tonight. But I just wanted to share what I found in case someone else was trying to do this too with PPro.
http://dve.teletex.ru/en/dvrecdate.shtml
John McGinley is offline
Old June 3rd, 2005, 11:27 AM   #994
Eddie Lotter has a free utility that will generate timecode. You can get it at http://www.2writers.com/download.htm.
Christopher Lefchik is offline
Old June 4th, 2005, 12:13 AM   #995
Ok that makes a little more sense. Except I will have to go back and double check to see if they had audio on te m2v ones. Thanks.
Vlog On!
http://youtube.com/clintus
Clint Comer is offline
Old June 4th, 2005, 05:14 AM   #996
Thanks for the help guys.
Al Ioimo is offline
Old June 4th, 2005, 07:17 AM   #997
Premiere Pro 1.5 Trial, is it same as full version?
hi all,
just got my new pc & keen to try premiere pro 1.5. i just finished filming a wedding & would like to try premiere to edit it with & looking to purchase if i find the workflow good.
i realise it only 1 month for the trial but is there any feature or saving capabilities disabled in the trial? i'd like to edit my whole wedding video to get right into the good & bad features of premiere to find if its suitable but dont want to start editing & not be able to export, save, etc...
thank you....
James Darren is offline
Old June 4th, 2005, 01:22 PM   #998
The trial version does not include the Adobe Media Encoder, which is required to create DVDs and other compressed formats.
http://www.sareen.tv
Aanarav Sareen is offline
Old June 4th, 2005, 06:33 PM   #999
If I were you, buy the boxed version. this trial does not have the "go to adobe to buy" thing after the trial ends, instead just a box to make the software completely unusable. so in a sense, NO, IT IS NOT THE SAME! Uninstall it immediatly!
Jack Zhang is offline
Old June 4th, 2005, 08:00 PM   #1000
ok but i can still export as an .avi file then use another program like tmpgenc to encode to dvd?
Old June 4th, 2005, 09:53 PM   #1001
Yes, you can. Download Adobe Encore DVD to transcode your AVI file to MPEG2.
Old June 5th, 2005, 12:28 AM   #1002
PPro DVD export
What are the best settings to use when exporting direct to DVD with Preimere Pro 1.5. I am exporting 45 minutes clips shot with GL2.
Thank you
Thanks for your help everyone.
Thomas Fraser is offline
Old June 5th, 2005, 10:36 AM   #1003
Thomas,
I've never used PPro to do DVD, so I might not be able to help you. However, I do a lot of DVD using PPro to create my movie, then use Encore to make the actual DVD. I export to .avi from PPro for two reasons. One is to have an avi copy I can send back to tape for a back-up. Second is to let Encore do tha actual transcoding. I say Encore because I have the Adobe Collection, but you can use any DVD program. I know this doesn't answer your question, but it does show you a different option.
Dan
Wow! That thing must have cost an arm and a leg! - - - It did! I used to have three of each.
Dan Mumford is offline
Old June 6th, 2005, 01:12 PM   #1004
I use the PPro 1.5 and Encore combo too Thomas. Do you have Encore or another DVD authoring program?
I will be in Sundance 18-30th - if you'll be there drop me a line and come see my movie HUNTING CAMP! (click below)
John C. Lyons is offline
Old June 6th, 2005, 04:37 PM   #1005
Glow effect in Premiere Pro 1.5
I have a title that I would like to put a glow effect on. Is there a way to do that in the title designer in Premiere Pro 1.5? What I mean by glow is an area of color that follows the outside of the title but is feathered so that the farther out from the edge of the title you go the fainter the color is. I hope that makes sense.
Nate
Nothing = That which rocks dream about.
Nathaniel Sisson is offline
