Adobe Premiere & Premiere Pro discussions from 2005 - Page 35 at DVinfo.net
Adobe Creative Suite
Old March 10th, 2005, 03:24 PM   #511
Color Finesse is very good for matching cameras from what I've seen of it. About $600USD.
Glenn Chan is offline
Old March 10th, 2005, 06:33 PM   #512
I'm not trying to be funny here, but did you put the XL in VCR mode? Some times it's the simple things that bite us.
Dan
Wow! That thing must have cost an arm and a leg! - - - It did! I used to have three of each.
Dan Mumford is offline
Old March 10th, 2005, 11:56 PM   #513
2 Questions about the Premiere timeline/video tracks
Hi there
I am using Premiere 6.0. I have two simple questions....
I have two video tracks for an interview. Video track 1 is the full uninterupted video of the interviewee. Video 2 is the video of the interviewer, broken up in clips for only when he is asking questions.
I have to:
1) now add video effects to all the clips in video 2. There are a lot of clips. Is there a way to add the same video effect (just like a brightness & contract adjustment) to them all at the same time?
2) I want two add two emtpy video tracks Between video 1 and 2, so I can add an effect onto video 1. Is there a way to do this, or do I have to move all the clips in Video 2 up, manually, one at a time?
Thanks.
Ronald Lee is offline
Old March 11th, 2005, 04:31 AM   #514
Hi Ronald,
1) You can copy and paste effects from 1 clip to another. Simply right click on your first clip with the effect, then choose copy. Then right click on your second clip, and choose paste attributes. Another dialog will appear asking what attributes you wish to paste. Of the top of my head I think that effects is an option, so choose that.
2) First add your 2 more video tracks. Then use the group tool, select your clips in track 2 and then click and drag them to track 4.
I don't have Premiere 6 in front of me at the moment, but from memory I think thats how to do it.
Hope this helps,
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline
Old March 11th, 2005, 05:31 AM   #515
Capt. Quirk
Ed's pretty much dead-on. In a situation where you have to add effects to clips, it is easier to do it to the entire clip, then cut it up, rather than cut and paste to 50 smaller chunks.
www.SmokeWagonLeather.us
K. Forman is offline
Old March 11th, 2005, 09:46 AM   #516
Yes, it is in VCR mode. I should also point out some other things I've noticed since yesterday. I tried it with my Dad's GL2, and I had the exact same problem. However, I downloaded a dedicated capturing program (Scenalyzer 2.1), and that works, which seems to pretty strongly imply a Premiere problem rather than a FireWire problem or a camera problem.
John Rowan is offline
Old March 11th, 2005, 07:46 PM   #517
How to show/burn timecode in Premiere?
Hi there,
I'm on Premiere 6.0
Is there a simple way to show the timecode of some video you are editing, burned into the video? Perhaps in the bottom of the video, where the bottom black bar is (for widescreen video)?
This would help with editing and getting our EDL for out online masters.
Premiere will just read whatever timecode is on the source video, correct and automatically put together the EDL that represents your project file?
thanks.
Old March 12th, 2005, 04:27 AM   #518
From memory you can paste all the effects that you've copied to multiple clips - selected using the dotted rectangle tool.
Jon
Jonathan Nicholas is offline
Old March 12th, 2005, 06:42 AM   #519
As far as I am aware Premiere does not support burnt in timecode (BITC). I remember there being a work around/ plug in that someody produced, But I don't know where it is...
Try a search for BITC or burnt in Timecode.
The only machine that I am aware that does BITC in real-time and does it extremely well is a Lightworks Touch. But then again you are looking at aboout £16,000 for one...
Ed Smith
Hampshire, UK
Ed Smith is offline
Old March 12th, 2005, 07:05 AM   #520
RED Code Chef
Sony Vegas (another NLE) can do it as well, it is kinda real-time.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old March 12th, 2005, 08:34 AM   #521
Avid
Richard Alvarez is offline
Old March 12th, 2005, 04:01 PM   #522
Trimmed project
I was wondering, when I run the project trimmer out of the project manager, will it render out the new avi's without audio if I do not use the audio in the sequence? Or will it render out the audio if I originaly captured the audio regardless if I use it or not? If so, is there a way to render out the new avi's without the original sound?
Vlog On!
http://youtube.com/clintus
Clint Comer is offline
Old March 12th, 2005, 05:16 PM   #523
Timecode Frame Generator
Perhaps this timecode frame generator would be of some use?
David Yuen is offline
Old March 12th, 2005, 11:51 PM   #524
Output to DVD looks bad on TV
I hook the gl2 up to the tv... no edginess, no blurring.... just great footage.
I edit in premiere 1.5 and export to dvd... now have blurry movement and edgy lines. Set to high quality, 2 pass, 720x480, 4mb.
What in the world is the problem? I thought from an earlier post it might have been the lighting but now after plugging straight from camera to tv i know it can't be that.
It's something to do with software, but what?
Any info from anyone with the same experience and how to fix this would be great!!!
Jay Stevens is offline
Old March 13th, 2005, 03:06 AM   #525
Any time you compress video, you're going to lose quality. Try playing around with your export settings a little bit. I've had good results by doing the VBR 7mb 2-pass encoding, but try changing settings and find the results which work best for you.
Brent Ray is offline
