Adobe Premiere & Premiere Pro discussions from 2005 - Page 18 at DVinfo.net
Adobe Creative Suite
Old January 28th, 2005, 03:25 PM   #256
Check out Wrigley Video
You may want to view the free video tutorials at Wrigley Video. It will help you with keyframing.
David Yuen is offline
Old January 29th, 2005, 10:35 AM   #257
How many audio tracks can you have at once?
I previously used Windows Movie Maker 2 to edit video and I was annoyed that I could only have two audio tracks, which I used for the orginal audio and music but if I wanted sound f/x I'd have to get rid of the music. How many audio tracks can you use in Premiere Pro?
Drew Meinecke is offline
Old January 29th, 2005, 10:56 AM   #258
I believe its unlimited, or perhaps 99. In avid, you are "limited" to 24, but you can always nest and mix down. I think most people would be happy to have at least 8... dual tracks for dialogue, effects, music and ambience at the minimum.
Richard Alvarez is offline
Old January 29th, 2005, 02:09 PM   #259
Exporting to Mpeg-2 in Pro 1.5
Question about this topic. When I go into the media encoder and selest mpeg-2 or mpeg-2 DVD there are lots of pre-sets. This is something new to me from the older 6.5 version. How do I read this? How do I know what settings to use? What are you using?
Something I noticed under Mpeg-2 is there is no 720 60i, it says 60p. Not sure if this is a typo or what. When I click on it it does say 60fps not 30. Under the dvd option there isn't a high quality 16:9 option. Why is this? Are two passes better than one?
Some insight on this would be great. thanks.
Vlog On!
http://youtube.com/clintus
Clint Comer is offline
Old January 29th, 2005, 02:11 PM   #260
Mpeg-2 codec
Is there a better mpeg-2 encoder than the one that comes with Premiere? Not saying I don't like it but I'm sure there are some others out there that might give better image quality or compression. Thanks.
Vlog On!
Old January 29th, 2005, 06:44 PM   #261
Changing the color of a tower
I was wondering if I film a large gray stone tower, is it possible for me to change the color of the tower realisitically to black?
Old January 29th, 2005, 08:40 PM   #262
Jim -- I have not needed to do any keyframing in Premiere Pro since my last post. The next ad that will require motion keyframes will be done in 6.5, simply because it's a reedit of an old spot that I originally did in 6.5. But so far I've not had any problems with either 6.5 or Pro.
John Britt is offline
Old January 30th, 2005, 04:23 AM   #263
RED Code Chef
That last part should certainly be possible. Give it a try!
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old January 30th, 2005, 05:31 AM   #264
RED Code Chef
Drew: with all due respect I don't think you understand what you
are asking. Yes, it can be done with the AVC because it contains
After Effects & Premiere, both who support greenscreen removal
etc. Any program with such a feature can help in that regard
(which I already explained in my first replay and gave you a direct
answer that PPro can do this, After Effects can do it ever better).
However, this is very complicated stuff and takes a lot of practice.
There are no specific tutorial for your questions (crowd replication,
arrows etc.)
But if you did a google search (like I have done) like:
greenscreen OR bluescreen tutorial
You'll find links (including an after effects 4.0 tutorial) like:
http://www.jushhome.com/Bluescreen/Bluescreen.html
http://www.jushhome.com/HiddenPhanto...p/MSPComp.html
http://www.beepworld.de/members33/da.../tutorials.htm
http://www.darkskies.info/key.html
http://www.swfanfilms.com/makingmovies.htm
This should give you an idea what it takes. You can also see the
difference in quality between certain keys (ie, the way the footage
is extracted from the green/bluescreen and then composited into
other footage).
Old January 30th, 2005, 07:59 AM   #265
RED Code Chef
Yes, do a search on the boards with the following:
Procoder CCE Tmpgenc
You'll find lots of posts (specifically by me) with more information
on better encoders. ProCoder seems to be the best at the moment
with CCE & TMPGEnc a close second.
p.s. Premiere uses the MainConcept encoder (Sony Vegas uses
it as well), which is good, but not great.
Old January 30th, 2005, 08:01 AM   #266
RED Code Chef
60i is probably called 30 fps interlaced (I don't have Premiere).
Usually multiple pass encoding (VBR) is better than single pass
(CBR) encoding indeed, the more passes the more efficient it can
encode the video (and the longer the encode will take). I've seen
encodes of 7 or 9 passes (with CCE or TMPGEnc, see your other
thread) that looked very very good.
Old January 30th, 2005, 08:28 AM   #267
RED Code Chef
It might, depends on things (like the background etc.). What you
need to look at is color correction and more specifically a secondary
color corrector. This allows you to isolate a certain color (just the
gray, and if that was in other parts of the picture you could first
mask out just that section (on a duplicate track) and then put the
secondary CC on there) and then shift it in color or intensity etc.
Old January 30th, 2005, 01:40 PM   #268
I found out the hard way that Premiere does not have built-in capability to properly edit MPEG files...
Once I got to use a plug-in, everything worked out fine.
Rich Wong is offline
Old January 30th, 2005, 03:12 PM   #269
How does the sorenson pro mpeg2 codec measure up??
John Hartney
Elgin, Illinois USA
847.742.9321
John Hartney is offline
Old January 30th, 2005, 06:01 PM   #270
Ok cool so it's like cleaner, it's sole purpose is just encoding. Thanks alot Rob. As usual, you're the man.
Vlog On!
