Adobe Premiere & Premiere Pro discussions from 2005 - Page 106 at DVinfo.net
Adobe Creative Suite
Old September 24th, 2005, 11:09 AM   #1576
I had this problem with my new computer and all I did was download the latest video driver and the problem went away.
good luck
Michael Dempsey is offline
Old September 24th, 2005, 05:25 PM   #1577
premiere audio question!?!?
i just recorded a voice over and i'mjust getting audio from the left channel?
how can i have both right and left channels, what do i need to do in premiere 1.5
thanx
sorry if its a noob question
Saturnin Kondratiew is offline
Old September 24th, 2005, 05:34 PM   #1578
thanx
First, If you recorded on a stereo track with a standard mono mic, you would probably have just one side. You could maybe record to a mono track and that would play on both speakers I think. If you did record to a stereo track, maybe just copy it and paste to a new mono track.
Second, may just duplicate and paste inside the stereo track.
I didn't open up my Premiere, so if this does not work let me know and I will.
Good luck--Mike
Chapter one, line one. The BH.
Mike Teutsch is offline
Old September 24th, 2005, 09:51 PM   #1579
Open up the effects bin and navigate to the stereo audio effects category. Drag the Fill Left effect to your narration clip(s). This will copy the left audio channel to the right audio channel. (Yes, that is not a typo; while it may sound counterintuitive it is the Fill Left effect that duplicates the left audio channel to the right channel.)
Christopher Lefchik is offline
Old September 25th, 2005, 09:51 PM   #1580
Sometimes an uninstall followed by a new install will cure strange behavior in Premiere Pro.
John Bennett is offline
Old September 26th, 2005, 12:09 PM   #1581
Thank You John, I will try that some time this week. Will let you know What happend after that.
Mike Quinones is offline
Old September 27th, 2005, 10:45 AM   #1582
Would you guys tell me more about this cinelook plugin? Do you mean the "cineform" plugin you get when you upgrade to Premiere Pro 1.5.1?
Interesting, if true. And interesting anyway.
Hugh DiMauro is offline
Old September 27th, 2005, 11:52 AM   #1583
You get the ultra handy tip of the day award.
Jerry Porter is offline
Old September 27th, 2005, 01:15 PM   #1584
Converting to MP3 format
I have been asked to record a voice over and convert it to mp3 so i can just email the vo because of a time crunch. How do i do this in PP1.5?
Thanks in advance for the help
Ryan Douglas is offline
Old September 27th, 2005, 04:58 PM   #1585
Can you export Quicktime movies directly from Premiere?[you might need Quicktime Pro]
If so, I would imagine you can export just the audio portion as a AIFF file-WAV file and then encode to MP3.
Apple's Itunes does audio encoding/compression with whatever format you want.
John C. Chu is offline
Old September 27th, 2005, 10:23 PM   #1586
Driver
Mike,
I use windows XP would I look for the video driver at a micro soft site? I have never really had the problem stay as long as it has. Usually just a shut down and reboot and all was well??
Gus
Dale Guthormsen is offline
Old September 27th, 2005, 10:38 PM   #1587
You can't export directly to MP3 from within Premiere Pro. You'll have to follow John's suggestion and export to another audio format first before converting to MP3.
Old September 27th, 2005, 10:42 PM   #1588
Why thank you, that is quite kind of you.
Seriously, though, I know about this effect because I have had to use it myself. Audio recorded with mono lav mics kind of require it.
Old September 27th, 2005, 11:37 PM   #1589
"Cant' Activate Recorder" error.... no fix?
I had this problem once on my old computer but it was a funky audio filter installed with some video codecs. This time, I have NO clue. Everything worked great but last week Premiere stopped being able to capture. Windows Movie Maker works so I know it is not a hardware issue. NONE of my decks or cameras will work, NONE! Adobe has no answer. I have re-installed the program AND Windows but no change. As recommended I uninstalled MyDVD, still nada!
Using another program to capture is not an option. Any ideas? This is pretty flippin silly! I can output to tape fine just cant control ANY DV device which means I cannot capture or batch capture.
ash =o)
Ash Greyson is offline
Old September 28th, 2005, 12:35 AM   #1590
If your project settings are set to widescreen, you should be able to import a 4:3 clip and have it take up the full width.
Mark Utley
Mark Utley is offline
