Serious Magic DVRack - Page 19 at DVinfo.net
Adobe Creative Suite
Old March 16th, 2006, 05:23 PM   #271
Originally Posted by Brian Standing
Actually, if you have two firewire ports in your computer (or 2 firewire cards), DV Rack will do this automatically. Hook 'em both up, right-click and switch.
Works very well.
A/B? Of course. Didn't think about that... :)
Stephen Finton is offline   Reply With Quote
Old March 19th, 2006, 07:16 PM   #272
You shouldn't have any problems. The requirements listed for the software don't mention anything extraordinary regarding video adapter, and it's not the type of application that would normally demand any heavy processing from the GPU.
Robert M Wright is offline   Reply With Quote
Old March 20th, 2006, 07:45 PM   #273
Serious Magic
Generally speaking, the SiS chipsets work fine. If you do run into problems, get the latest driver from www.sis.com and you should be fine.
Karl Soule'
Product Marketing Manager, Serious Magic Professional Products Group.
ksoule@seriousmagic.com
Karl Soule is offline   Reply With Quote
Old April 9th, 2006, 07:34 PM   #274
Sponsor: VASST
Can Ultra 2 defocus a virtual set background?
I’m trying to achieve a greater depth of field by making the background slightly defocused in Ultra 2. This works for backgrounds that you supply yourself (just click the background or foreground layer and apply DeFocus) but no amount of clicking on the virtual set background will allow the defocus to work. Is there any way to defocus the virtual sets?
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline   Reply With Quote
Old April 10th, 2006, 04:36 PM   #275
Serious Magic
Go to View - Displayed Inputs - Pre-defined (or just hit Alt-P.)
Select the Vset layer you wish to defocus. Go to the Input tab, and move the Defocus slider.
Karl Soule'
Old April 10th, 2006, 09:46 PM   #276
Sponsor: VASST
Thanks, that works great, but only seems to work if the background is static. I’m using the Digital Studio backgrounds and the defocus control is grayed out. :( But it did work on the Library and I’m using that too. Still, the defocus is a great feature. Thanks,
~jr
Old April 11th, 2006, 01:06 PM   #277
Serious Magic
It does depend on the set. In MSL1, since many of the sets were developed concurrently with ULTRA, some of the advanced functions like defocus were locked out. On newer tracking shots in MSL 2, 3, and 4, you can defocus during the tracking shots as well.
Karl Soule'
Old April 12th, 2006, 01:08 PM   #278
Serious Magic
As of mid-March, the official forum has been updated and moved here: http://www.seriousmagic.com/msgboard/
Karl Soule'
Old April 15th, 2006, 10:11 AM   #279
Difference Between Ultra 2 and Ultra Key?
What are the differences, if any, between these two?
Aviv Hallale is offline   Reply With Quote
Old April 15th, 2006, 12:07 PM   #280
Serious Magic
Ultra Key was the original ULTRA 1.0. It's the very first release of the program, which changed its name to ULTRA very shortly thereafter. Version 2 of the program was released about this time last year, and it includes a ton of new features and improvements. Some of the highlights are faster rendering, HD support up to 1920x1080/60p, user-controllable virtual shadows/reflections, paint mask, multi-point pan/zoom, and more. Here's a link for a full rundown: http://www.seriousmagic.com/products...hats_new_in_2/
Karl Soule'
Old April 20th, 2006, 10:23 AM   #281
I use the DataVideo SE-500 4 input S-Video switcher. It works well and features 4 frame synchronizers for glitch free switching and color correction on each input. It is available for under $1000 and does a nice job. I output that to a Canopus analog to digital converter for firewire input to DVRack.
Paul Lohbauer
ProMediaDigitalVideo.com
Paul Lohbauer is offline   Reply With Quote
Old April 27th, 2006, 09:18 PM   #282
Guest
Posts: n/a
Ultra 2 - Mac to PC Workflow Options
Karl,
I'd like to buy Ultra 2 if the following workflow, well... works.
1) Record in front of greenscreen (ReflecMedia) with HVX200 using P2 cards.
2) Import footage into Mac FCP 5.0.4 (not Universal) on a G5 (using the normal HVX direct to HDD, then to G5 workflow), import into FCP, edit then export as a Quicktime H.264 movie and save it to an external HDD.
3) Remove the HDD from the Mac and attach to a Sony PC Vaio.
4) Open up Ultra 2 and work with it to do whatever you would normally do with the footage in Ultra 2 to produce the final effect with the greenscreen footage merged with the Ultra 2 backgrounds.
Would this work?
Then, if so - What are the movie exporting options? Could I export it back into a Quicktime H.264 format so I could then move the footage made on my PC back to my Mac, work with compressing the footage one last time in Sorenson Squeeze 4.3 on into a .flv format for Flash?
Or is there a better way, so the footage would not have to be compressed 3 times (twice in QT, once as an .flv)?
My ReflecMedia stuff arives on Monday and I'm trying to prepare the best I can. Thank you for being an active member of this forum.
Old April 29th, 2006, 01:34 PM   #283
DV Rack 30-day trial overlay "pumping"
Hi all!
Downloaded the 30-day trial today to just check it out during a commercial shot in a couple of days (using a XL-H1). We'll record to tape anyway but I thought that I'd check it out, and if it's as good as people say, we'll get it.
Everything seems to work ok apart from a very annoying overlay brightness "pumping" issue. If I record a file and play it back in Windows Media Player, the pumping is NOT there. If I play it back in DV Rack it's still visible. And, and that's slightly scary, the "pumping" is clearly visible on the scopes.
Also, if I scroll the interface up/down, the overlay turns black ever so often.
My laptop is a Intel P4 3Ghz HT with a Gb of ram and a 7200 rpm drive using a fairly old Radeon 9600 Mobile using the latest driver possible, which is kind of old. At least a year and a half. CPU usage never goes over 56% during capture. DXDiag for the Grapichs below.
Any suggestion?
Best regards,
Max Hagelstam
Display Devices
Card name: MOBILITY M10
Manufacturer: ATI Technologies Inc.
Chip type: MOBILITY RADEON 9600 Series AGP (0x4E50)
DAC type: Internal DAC(350MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4E50&SUBSYS_05001558&REV_00
Display Memory: 128.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Standardbildskärm
Monitor Max Res:
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6378 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/12/2003 13:00:00, 369152 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Saknas
Mini VDD: ati2mtag.sys
Mini VDD Date: 8/12/2003 13:00:00, 594432 bytes
Device Identifier: {D7B71EE2-0D10-11CF-026E-0A25A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4E50
SubSys ID: 0x05001558
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Max H
Max Hagelstam is offline   Reply With Quote
Old April 30th, 2006, 11:17 PM   #284
Serious Magic
Are you absolutely the problem isn't in the recorded clip? If I'm understanding the problem, you are seeing the luma values on the waveform fluctuate slightly, creating an "oscillating" effect. I have seen this just recently, and it was caused by an oddball set of flourescent lights, and an incorrect shutter speed setting in the camera. (60Hz lighting and 1/50th sec shutter speed is a BAD IDEA.) Setting the shutter speed in the camera to match the lights corrected the problem.
If that could not be the problem, then I would get an updated video card for this system - 2003 drivers could cause a number of problems, including a flickering black screen. Updated drivers will be available from your laptop manufacturer, or from www.omegadrivers.net if your laptop manufacturer hasn't kept up to date.
Karl Soule'
Old May 10th, 2006, 07:49 AM   #285
A couple of DVRack Questions
Hi, I've been using DVrack for a little while, but not all the time. I have a couple of questions that I can't seem to figure out.
1. What is the best res. for the laptop screen? I have recently ran it with HDV coming from my Z1u at 1280 and it looked really good. There was a little delay in the video, but it looked better on the screen than at 1024. 1024 looked grainy on the screen.
(BTW I understand that it is just the monitor and doesn't effect the video being captured)
2. When recording from my Z1u, I had primary audio coming from a mixer into channel 1 and then had a shotgun for ambiant into channel 2. On the DV Rack screen, the main audio was showing up on the Right channel (which is usually Ch.2) and the shotgun was on the left channel (which is usually channel 1). I'm wondering why?
David
David Stoneburner is offline   Reply
