XDCAM not importing into Premiere at DVinfo.net
Adobe Creative Suite
Old July 24th, 2009, 08:01 PM   #1
I am having my intern work on a project in Premiere Pro CS3.2 and I can not seem to import some footage from my EX3. The same thing has happened on my workstation after I reformatted a few days ago. I says it is unrecognized footage. So i googled the problem and was told to rename the files from *.mp4 to *.m4v or *.mpg. Now this allows me to import the footage but no audio shows up into premiere. We even reformatted the computer and re-installed everything. Still have the same problem. These files worked before we reformatted and also works on CS4. I am out of ideas...please help
Mitchell J. Skurnik
http://www.mjcsstudios.com/ - EX1, 4x hoodman 16GB, Libec Tripod, Sony LAV
Mitchell Skurnik is offline   Reply With Quote
Old July 25th, 2009, 07:33 AM   #2
depends... when you import do you see any info on the timeline in the audio portion and
the audio just doesn't playback???
If this is the case I'd check the preferences... go to " edit " , " preferences ", "audio hardware" and check to make sure you have this setup correctly... also look at the "audio output mapping " while there too.
I loose audio everytime I load or reload my blackmagic drivers... so that might help you
get your audio back
Old July 25th, 2009, 08:35 AM   #3
Are you using Clip Browser? If not, you should use it, and not Windows Explorer.
Brian Barkley is offline   Reply With Quote
Old July 25th, 2009, 10:44 AM   #4
There is no audio in the track at all when imported
Mitchell J. Skurnik
Old July 25th, 2009, 11:21 AM   #5
I'd have to go with Brian....
Try clipbrowser and convert the files that way then bring those into the timeline..
Old July 25th, 2009, 11:27 AM   #6
These are both windows XP machines...I shouldnt have to re-wrap them
Mitchell J. Skurnik
Old July 25th, 2009, 04:23 PM   #7
did you check to see if there is a video file and a audio file in the same directory??
I've seen this before...
If so you import the video and drop the audio below the video on the time line...
Old July 25th, 2009, 04:27 PM   #8
No other files but meta data and stuff
021_0096_01.MP4
021_0096_01.SMI
021_0096_01I01.PPN
021_0096_01M01.XML
021_0096_01R01.BIM
I wonder if it is because my company recently changed AV protection to Sophos...could a firewall, malware, virus protection be doing this?
Mitchell J. Skurnik
Old July 27th, 2009, 05:46 AM   #9
Strange thought, but are you sure audio got recorded? Place the memory cards back in camera and listen through headsets to make sure that audio is indeed there.
Old July 27th, 2009, 06:10 AM   #10
try using the clip browser to see if it will import to a hard drive OK
Ed Kukla is offline   Reply With Quote
Old July 27th, 2009, 08:31 AM   #11
Audio is there...shows in CS4. I cant place it back in the camera as I rented it.
Mitchell J. Skurnik
Last edited by Mitchell Skurnik; July 27th, 2009 at 02:40 PM. Reason: Should say CS4 not CS3
Old July 28th, 2009, 05:45 PM   #12
Hi Mitchell,
I had the same problem - I could import ex1 .mp4 files fine and dandy - and then one day - not. 'Unrecognised files' error or something. I was running XP64 at the time and having dramas with other drivers etc. So I switched back to XP32, re-installed the production suite and updated Prem to 3.2 - hey presto, XDCAM EX native functionality back again.
Now, I can't say whether this was an XP issue or some other conflict somewhere - OR - Adobe did an update which I D/L and installed automatically and that screwed things up. The only advice I could give is try re-installing Premiere again and see if it works for you the way it did me. Probably not what you wanted to hear I know, but perhaps just re-installing the application - rather than doing a full OS reinst will be enough.
Regards,
David.
David Warrilow is offline   Reply With Quote
Old July 28th, 2009, 05:55 PM   #13
I have re-formatted a few times and re-installed premiere before reformatting with no luck. I ended up just converting the mp4's to mpeg 2's.
I would still like to know what is causing the issue :(
Mitchell J. Skurnik
