Mercalli at DVinfo.net
Adobe Creative Suite
Old July 14th, 2009, 01:16 PM   #1
Mercalli
I have downloaded the demo version, and am not able to see the program, in the "video effects" section of Premeire Pro 2.
Any ideas?
I was told I have no vision, but boy do I see great!
Sam Mendolia is offline   Reply With Quote
Old July 15th, 2009, 11:45 AM   #2
I use Mercalli with CS4. I wonder if the installer has gotten messed up as they transitioned to CS3 and CS4. In my case it's in a bin called proDAD, and the function is Mercalli. Is there a search function for video effects in Pro 2 - if so try to search for Mercalli or proDAD. Otherwise it may be time to e-mail proDAD.
I use the program for minor stabilization and it works well. Forget about correcting major shakes and bumps.
Charles W. Hull is offline   Reply With Quote
Old July 17th, 2009, 06:32 AM   #3
Thank you Charles,
I did find the folder it was installed into. Reading the install details, before you hit "OK" helps.
But, I did this several times, and it would install into two different folders, within the Plugins folder, each time.
So, I copied the files, and put them in both folders, "Common" and "US-Eng".
Interesting thing is that, when running Vegas, it was there, and I did not have to go searching for it.
I now have access to the program, have have to read the manual, on how to use it properly.
Then I will get a real copy, once the time runs out on this demo version.
