Thread Tools
Search this Thread
Saving Bin Heading Layout?
I'm trying to save Bin Heading Layouts in Premiere CS4. It's just not working. I found this page ( http://help.adobe.com/en_US/Premiere...5-1EFD2101355B ) and it says:
Save, switch, or delete metadata sets If you use multiple workflows, each requiring different sets of displayed metadata, you can save sets and switch between them. 1. From the options menu for the Metadata panel, select Metadata Display. 2.Do any of the following: *To save a customized set of displayed metadata, click Save Settings. Then enter a name, and click OK. *To display a previously saved set of metadata, select it from the pop-up menu. *To delete a previously saved set of metadata, select it from the pop-up menu, and click Delete Settings. This is what I'm having trouble doing: *To display a previously saved set of metadata, select it from the pop-up menu. I save the layout after naming it but the pop up menu is grayed out. It displays the name but I can't select any of the layouts I saved. Then when I exit that window and come back, the name is gone from the box and I still cannot select any of the saved bin layouts. Is this a bug or something? Does anyone else have this issue? |
