Problems with notchy output
I for the life of me can not get smooth output (rendered) footage for my project!
I have tried everything I can think of but to no avail. The footage was shot from a Pana HPX 170 720p 24 frames (not PN, but P) looks great playing from the HPX, but when trying to get smooth files, initially size does not matter....... I get what appears to be @ 12 frames / second. My computer is up to speed as far as Adobe says..... So basically my questions is, What format, codec, settings to use to output smooth, good looking video at roughly 720 x 480 specs (not strict at this point) any file size at this point. Does not matter, I just would like to see a smooth output. The lenght is only @ 9 seconds as well........ And I thought the Helicopters we are shooting from where aggravating!! |
Brett... This can be done and believe me, we're here to help but I think we need more info. What output format are you looking for? A transcode format or final delivery or render back to tape? It matters because the workflow and tools will determine the proper path.
Tell us where you are (tools you have), where you want to go, and we'll do our best to help you get there. |
Got the solution!!!!!
It was a pull down problem, going from 24p..... In Premiere Pro CS4, you can right click on 24p footage and select, remove pull down from the interpret footage tab........ Just did a quick sample and it looks great!!!! Like I said, I thought the Helicopter side of aerial video was tough......... Thanks for your quick reply though! |
Below is a link to some footage we have shot for those that are interested.
Vista Aerials - Aerial Photography and Video |
