Tapeless and CS3 at DVinfo.net
Adobe Creative Suite
Old January 30th, 2009, 01:09 AM   #1
Tapeless and CS3
I just purchased a Focus DTE recorder for my XH-A1 FS-C 100 and love it, but having problems getting files into CS3, it can record to quicktime and m2t, quicktime does not work and m2t crashes CS3 unless I use Cineform to convert it to avi first.
Would upgrading to CS4 fix any of these problems?
With CS4 would I loose many apps that I am using with CS3 like Cine Form, Magic Bullet etc?
2 Canon XF305's
Kyser Photography www.kyserphoto.com
Denny Kyser is offline   Reply With Quote
Old January 30th, 2009, 08:46 PM   #2
This will sound obvious, but you have a problem there! Either with your FS-C or your installation of CS3. I also have the FS-C and CS3 and have no trouble whatsoever importing M2T files from the FS-C into Premier Pro CS3. Make sure you have the latest firmware on the FS-C (it's available on their website).
Julian
Julian Frost is offline   Reply With Quote
Old January 30th, 2009, 09:07 PM   #3
I checked and I have the most up to date firmware, I can convert it with Cineform to a Cineform AVI file and its fine, not sure why premier is struggling with the downloaded files
I should add, can open it with After Effects too, just not Premier Pro CS3
2 Canon XF305's
