CS4 - how to scene split HDV? at DVinfo.net
Adobe Creative Suite
Old January 24th, 2009, 11:10 AM   #1
How can i capture and split the scenes with my fx1000 footage??
I use HDVsplit normally but would like to use CS4 only if possible to capture 60i/24p and 30p depending on my projects.
I tried last night and couldnt click on scene split.
thanks
Jean Rousseau is offline   Reply With Quote
Old January 24th, 2009, 12:50 PM   #2
Premiere still doesn't do scene detect in HDV mode.
If you only need to capture selected clips, batch capture is best. If you need the whole tape but broken up instead, you can make subclips manually. Otherwise HDVsplit is probably best.
Old January 24th, 2009, 03:29 PM   #3
thanks for the reply!
Old January 24th, 2009, 11:38 PM   #4
CS3 scene detects HDV if Cineform is installed. I assume this will also be the case in CS4, however Cineform has not released their CS4 update yet.
Graham Hickling is offline   Reply
