3 Monitor Setup at DVinfo.net
Adobe Creative Suite
Old January 21st, 2009, 12:49 PM   #1
3 Monitor Setup
Hi there,
Can someone help me out with setting up a 3rd montior to preview my output.
I'm using the Matrox RT X2 card with Adobe Pro 2.
I currently use 2 monitors which is strecthed across 2 monitors and would like to preview the final output on the 3rd.
I have tried setting it up from the breakout box RGB to VGA, but getting no signal.
The 2 monitors I have currently set up go outputs of my graphics card, so I asumed if I connected the 3rd monitor to the dvi output on the Matrox Card it would work, but no, no such luck.
Is there any settings I need to change in Adobe or Matrox, I have looked but can't seem to find anything.
If some kind person could help me out and explain how I can do it, I would appreciate.
The Matrox card is not the SD/LE version.
Regards
Wayne
Wayne Greensill is offline   Reply With Quote
Old January 21st, 2009, 03:52 PM   #2
The RTX2 card will only output from the DVI port in Matrox projects in Premiere (Plus WYSIWYG plugin apps). You must have a 1920x1200 LCD connected to it for it to work. It doesn't scale to lower resolutions.
For more information on these topics, check out my tech website at www.hd4pc.com
Mike McCarthy is offline   Reply With Quote
Old January 21st, 2009, 04:26 PM   #3
Oh Sh#t. I've just been and brought a lcd which has 1280x1024.
Why don't they tell you this in the documentation?
Anybody want to buy a monitor? :o(
Old January 25th, 2009, 08:14 AM   #4
Hi Mike,
Thanks for the feedback.
Do you think the monitor I have linked below, the Samsung SM2343BW, would do the job?
Samsung LS23MYZABC - Samsung SM2343BW - SM2343BW wide screen (LS23MYZABC)
Old January 25th, 2009, 09:16 PM   #5
Never seen that one before, and it is not listed on Samsung's site. It is a 2K monitor, with is unusual. That is cool, but not what you really need. There are lots of 1920x1200 LCDs out there in the 23"-24" range.
That one may work, but I doubt it due to the low vertical resolution. It likely won't look as good as one with the exact native resolution of the Matrox output.
