Adobe Premiere discussions from 2002 - Page 3 at DVinfo.net
Adobe Creative Suite
Old February 23rd, 2002, 10:19 PM   #31
This happens to me on more complicated projects when I try to play an exported video, or just previewing the timeline. It has never happended when I use the 'Print to Tape' (not sure if that is exactly what it is called). Sorry, caffine is killing my memory - You go to 'file', 'export', 'Print to Tape'. Try that if you haven't already and let me know what happens.
Justin Walter is offline
Old February 24th, 2002, 08:26 PM   #32
DR_Pepper_78,
STILL NO LUCK! I need to get some sleep this week, but I can't turn out projects with this mess. When I play it back it will go to the "blue no signal" screen of my VCR and then play through again creating that jump cut. Some times it will hiccup, and then go into a fast-forward mode. I have read about other people experiencing the same kinds of problems. My Premiere software is not exactly store bought either which may be part of the problem.
Dan
Dan Dorsey is offline
Old February 25th, 2002, 03:44 AM   #33
Try this.
FILE/EXPORT/MOVIE/MICROSOFT DV AVI
Then when it is finished, simply do
FILE/OPEN/...and select that file you just created. It will open up in a new window and just press "play" and should play back perfectly smooth. Give it a shot and let me know if that works for you.
Bradley Miller is offline
Old February 25th, 2002, 01:56 PM   #34
_redone_
editing
ive never imported premiere projects into after effects due to that reason..
i usually do all my color corrections, effects ect. in after effects.
then render a new avi to go to premiere for edit..
then output from there....
or vice versa i guess..
Adam Lawrence is offline
Old February 26th, 2002, 03:53 AM   #35
RED Code Chef
only problem with that is space & time. If I want todo
that and not loose any quality I need to export either
uncompressed or in a lossless format (ie, not DV). This
takes muchos diskspace and time. Not ideal.
I have been rethinking my problem. I only have like 4
dissolves or something. The rest are all straight cuts
which After Effects has no problems with. So it is not
too much work todo those 4 manually.
Too bad After Effects cannot run inside Premiere (or
vice versa) as a plugin..
Oh well.... keep on dreaming
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old February 26th, 2002, 02:16 PM   #36
_redone_
dv
yup..
thats the only down fall is space and rendering time
but if you figure out a way to import projects from premiere
flawlessly then let me know...
i found using the microsoft DV compressor works well..
not the best but it makes for a good compression without
a noticable loss of quality...and doesnt take up much space.
Old March 10th, 2002, 02:11 PM   #37
Many times the system is O.K. but we leave applications running in the background, often we are not aware that these resources are running. Make sure virus checkers and other such applications are not running and sucking resources away.
Andrew
Andrew Leigh is offline
Old March 12th, 2002, 11:27 AM   #38
Premiere 6 and 32/48khz audio
Has anyone mixed 32 and 48 khz audio in a premiere project? Adobe says to "avoid" mixing the two...but they don't say "you can't" !
I'd like to know what the possible problems that mixing would cause. (I'd like to export the finished project at 48K)
(Love this website!)
fargograf is offline
Old March 12th, 2002, 02:30 PM   #39
Registration Incomplete -- contact Admin.
I didn't realize that adobe actually says to "avoid" this?
I've actually tried this and have experienced some problems. Nasty ones. My PC runs WindowsXP with Adobe Premiere 6.01. I've got pretty decent hardware. I never expereince crashes...system runs smoothly. Well, guess I should say, hardly crashes.
BUT...I experienced my first serious crash after about so many months...and all because I mixed 32 and 48 khz audio in a premiere project.
It's been awhile since I've tried but from what I remember sometimes I can mix audio formats if I start with a 32 khz project. Sometimes is the key. If I started with a 48 khz project and imported video that included audio that was less than 48 khz...my machine would crash horribly. OR it could have been the other way around now that I'm thinking about it. It may have crashed from starting with a 32 khz and importing 48khz.
In any case, be careful. I would just fool around with it. There are some workarounds you can do but it's just something you have to play around with.
mdreyes23 is offline
Old March 12th, 2002, 04:49 PM   #40
mixed audio
I wonder if a 32 k file can be "converted" to a 48 k file? Anyone know?
Old March 13th, 2002, 05:41 AM   #41
RED Code Chef
Yes, that is possible. But you really want to avoid conversions
in sample rate. Any conversions for that matter, whether
sample rate, video fps or video resolution. Any conversion is
always bad to have (i'm not going to talk about compression
here!). But if really needed, it can be done! Try to get the
best audio applications or plug-ins to do this for you! I doubt
Premiere will have the routines todo this good. It isn't an
audio package afterall. I heard Steinberg WaveLab is pretty
good. But I suggest listening to a true audio expert or asking
one about this.
Old March 13th, 2002, 12:26 PM   #42
You can use sound recorder which comes with windows.
load the file in, click file>save as>> change, then choose the quality (CD quality), click ok and there we go.
Hope this helps,
Ed Smith
Ed Smith is offline
Old March 26th, 2002, 08:52 AM   #43
Premiere users
For anyone using Premiere this guide is quite useful.
http://www.adobe.com/support/techguides/premiere/main.html
Adrian Douglas is offline
Old March 26th, 2002, 12:59 PM   #44
Cheers for the link Adrian
Ed Smith is offline
Old April 1st, 2002, 11:52 AM   #45
It may depend on what track it is in.
I use Cinestream and not Premiere. However, the same techniques may apply.
In CS the general advice is to reserve a certain audio tracks for different sampling rates. Mixing different audio rates in the same tracks is well known for causing unusual and undesirable audio effects. By reserving these tracks for 32KHz these problems are avoided.
When rendering to the master audio track (AP) which can be set to 48KHz for the project, the system mixes the audio without resampling.
I am sure that probably applies for Premiere as well.
Nathan Gifford
Nathan Gifford is offline
