Adobe Premiere discussions from 2002 - Page 20 at DVinfo.net
Adobe Creative Suite
Old October 17th, 2002, 09:04 AM   #286
RED Code Chef
My experience is that most comes down to fast harddisks and
a clean system... more than CPU... Ofcourse that is my personal
observation / taste. Yours might differ. But hey, give it a try
and see.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old October 17th, 2002, 09:22 AM   #287
RED Code Chef
What you are seeing is the TV safe area. You do not see it on a
TV because it will not show this area, and when they build the
XL1 viewfinder they decided you shouldn't see it either (stupid).
You see it on the computer because the computer shows
EVERYTHING in the signal. If your output is for TV only you need
not bother about it. If you are also going down computer or
web you need to crop it out.
Old October 17th, 2002, 09:27 AM   #288
scanning picture into Premiere
Hello All,
I am trying to scan a picture into Premiere that is 5" wide x 6.75" high. But when I import it into Premiere it come out wider than high making it appear stretched out. What did I forget to do?
-SL
SammyLeopold is offline
Old October 17th, 2002, 10:03 AM   #289
find the optiong to turn off 'maintain aspect ratio', should fix your problem.
kermie
Zac Stein is offline
Old October 17th, 2002, 10:23 AM   #290
upgrade to 6.5
I did this recently and was glad to see the improved tools, faster editing, better titling that 6.5 provides. I'm not in front of my video library, but I think you may need a fairly fast CPU as a minimum for 6.5. -maybe check the literature at videoguys,com. Mike
Mike Rupp is offline
Old October 18th, 2002, 02:07 AM   #291
snafu005
Posts: n/a
thank u!
guess I'll hafta crop :(
Old October 18th, 2002, 02:10 AM   #292
snafu005
Posts: n/a
Captures in Premiere look too bright/washed out??
Today I noticed that all of my footage captured in premiere 6.5 is too bright. Much brighter than when the miniDV tape is viewed on TV played throug my XL1s
Is this a common problem? Should I just darken everything?
TIA1 =-)
Old October 18th, 2002, 04:37 AM   #293
Are you viewing this video on a computer monitor, or an external video monitor/television set? If you're just looking at it on a computer monitor, that's probably where the discrepancy lies. Always port the video out to an external video monitor, even if it's just a cheap television set, as it'll show you what the video really looks like.
Chris Hurd is offline
Old October 18th, 2002, 12:01 PM   #294
Right click the picture on the timeline> go to video options>> then select maintain aspect ratio.
You can also select what could you would like to be in the 'spaces'
Right click picture on the timeline> goto video options>> then select aspect fill colour>>> choose your colour>>>> select OK
Hope this helps,
Ed Smith
Ed Smith is offline
Old October 18th, 2002, 12:07 PM   #295
Thanks guys, it's a P3...
I was mostly worried if it would upgrade from 5.1 The buddy I bought the system from, is still "looking" for all his paperwork. I got the whole thing from him for 200 bucks, to send off with the kid. I am thinking it won't go up to 6.5. No sweat, I just didn't want to throw good money after bad... (Well, not bad really... pretty good for an old system.)
Richard Alvarez is offline
Old October 18th, 2002, 09:53 PM   #296
Like Rob said, it mainly comes down to fast harddrives. Even a PII will play video smoothly in Premiere if you have a fast disk. Render times will be long but you will have no trouble playing video smoothly
Adrian Douglas is offline
Old October 18th, 2002, 10:05 PM   #297
new problem
Thanks guys, worked beautifully! Here is the next problem the pictures are still coming out fuzzy. I scanned them in at the highest reolution Premiere could handle and then used Photoshop to resize them down to the size I needed. When I open them up in the bin they look great but when I export my timeline to video they look all fuzzy. Any thoughts from anyone?
-SL
Old October 18th, 2002, 10:28 PM   #298
Might be a square vs rectangular pixel issue.
To quote Josh Bass:
"Everything I've just written is probably wrong"
If you're not the lead dog...
the scenery never changes
Doug Quance is offline
Old October 20th, 2002, 03:05 PM   #299
Rick Reed
Posts: n/a
Adobe Premiere 6 & Kernel32.dll crash
Can't open Adobe Premiere 6.0. Getting "has caused error in Kernel32.dll, will now close". Anybody got common fixes for this?
Old October 21st, 2002, 03:48 AM   #300
Premiere for features?
I'm getting ready to put together a dedicated DV editing system (PC) and I was going to build with Avid XPressDV in mind, but I have read on this board that it has a very steep learning curve. So my question is: Does premiere have what it takes to edit and process a feature-length DV project and output it with minimal compression?
Any advice is appreciated.
Shawn
"Keep away from people who try to belittle your ambitions. Small people always do that, but the really great make you feel that you, too, can become great."
-Mark Twain
Shawn McBee is offline
