15 Frames Off-Sync Audio and Video at DVinfo.net
Adobe Creative Suite
Old December 18th, 2008, 12:21 PM   #1
Hi,
I have been capturing 1 school concert and 1 Town Chamber Holiday Party and they are all getting 15 frames off sync. I tried to capture in 2 cameras (Canon Xh-A1 that I shot with, and HV30 that use as a deck). Both camera pushes audio 15frames behind. They both shot in A1 HDV mode with 60i frame rate.
I am trying to edit on HDV 1080i 60i timeline.
I am using CS3 version of Premiere Pro and I am not sure what's going on.
If there are any more settings you need to know to help me out here, please let me know then I post'em.
My Chamber director really wants them in HD on their website so down converting is not an option here.
Thank you tons ahead.
JJ
J.J. Kim is offline   Reply With Quote
Old December 18th, 2008, 03:30 PM   #2
Capturing is a simple transfer of 0's and 1's. Nothing is changed during the transfer. Either the camera did not work correctly, or your system/setup/project is wrong for what you shot. Capturing can not cause a 15 frame out-of-sync. Maybe a dropped frame causes this. Give some more details.
Old December 18th, 2008, 03:37 PM   #3
I was using both XH-A1 and HV30 to capture, so I doubt both cameras have same problem.
The project setting is HDV 1080i 60i and was shot in HDV 1080i 60i. There was no dropped frame throughout the tape.
When I captured some other tapes in DV, nothing ever happened.
I am going to try to capture in DV project as HDV clip to see if same thing happens...
Old December 18th, 2008, 09:56 PM   #4
What version of CS3 are you using? Is it updated to version 3.2?
Eric Addison is offline   Reply With Quote
Old December 19th, 2008, 01:00 PM   #5
Yes, I am using 3.2.0 (374) version.
Is there any known bug for this version?
Thanks.
JJ
Old December 19th, 2008, 01:15 PM   #6
Never experienced this problem you are describing. You can try to capture with HDVSplit and see if you still experience this problem.
Old December 20th, 2008, 02:55 AM   #7
You could try replacing the ImporterFastMPEG plugin with this one - it was given to me by an Adobe tech to fix a bug in CS3 with the way it handles Canon 24F footage...it may fix your problem as well - but I can't promise anything!
Old December 21st, 2008, 01:51 PM   #8
How long are the segments that you are capturing? Anything over half an hour can cause the audio not to line up correctly.
Patrick Myers is offline   Reply With Quote
Old December 21st, 2008, 09:34 PM   #9
Actual footage is the whole tape, 63 mins, but I tried to capture only 1 minutes and same thing happened... still trying to figure out...
Old December 22nd, 2008, 01:42 PM   #10
I guess if nothing else works you could shift the audio over in the timeline but that's a fix you shouldn't have to do.
I, myself, hate when things don't work properly or as they should so I understand your pain. Kinda crappy problem. I'd love to hear what the solution is if you figure it out!
Triple E Productions - Award Winning Films/Services
www.PaulDV.com
Paul Del Vecchio is offline   Reply With Quote
Old January 2nd, 2009, 01:20 PM   #11
Audio Drop Out - Drop Frame GOP
What you are experienceing is very common, we fight this in our HDV workflow. When a drop frame occurs, the audio goes out of sync during capture usually 15 frames. The I frame seems to be the sync point for the audio, and if the P and B frames are gone, the audio drifts. It is a nightmare in post.
Here is my work around. It is a pain, but it has helped me save time in the long run. We started using HDV Split, (We used to use Scenealyzer) and set the program to stop captureing on a frame drop. I will then simply start capturing again after that point, and know where the drop out is, is a problem, but from there on, the tape captures and audio stays in sync.
If this is what you are experiencing, it sure beats re-syncing and searching for that dropped frame point.
If not...
Have your camera's been serviced? Maybe there is a head clog.
Do you have a Raid you are capturing too? I would test the Hard Drive Speed capture rate.
What kind of tape are you using, are you switching tapes? Stick with one brand, and if you are going with a cheaper brand, don't reuse the tapes - We get more dropouts with used tapes. less than 15% with new tapes.
Hope this helps...
George
Colorado Digital Video
Last edited by George Sickler; January 2nd, 2009 at 01:21 PM. Reason: additional thoughts
George Sickler is offline   Reply With Quote
Old January 3rd, 2009, 09:05 PM   #12
thank you very much, George.
Here is my reply for your question,
Originally Posted by George Sickler View Post
If not...
Hope this helps...
George
I always use Panasonic professional 63min tape, always. I have not gotten any service for my cameras, but I tried to capture with 2 different camera and same thing happened, so I am not sure if it's the camera. I am gonna re-create the project as SD for now, cause I don't think my client would want HD version any soon.
Old January 4th, 2009, 03:17 PM   #13
Premiere just isn't very good for capturing and doesn't like HDV much. (I end up editing in Premiere with Cineform - much happier)
HDVSplit is great, I haven't tried the stop-on-frame-drop work around though.
What works for me is running clips through MPEGStreamclip (free) and checking "fix timecode breaks".
Brad Tyrrell is offline   Reply
