Hard drive and graphics limitations in editing with CS4
Hi people, this is my first post here as we've just moved into the realm of HD and left SD- land forever. At least that was the plan. We bought some EX1's, upgraded to CS4 and now I find that our hardware seems to be way behind. We bought a new machine based on an Intel XEON E5440 2.83GHz quad-core processor with SAS 15000RPM HDD's and the graphics card is NVIDIA PCIE QUADRO FX1500 256MB HDTV DUAL-DVI graphics accelerator. We are editing mostly 3-camera shoots in full HD mode.
We are up and running but find realtime preview playback is a problem - the preview frame is worse than jumpy, it's almost frozen. My first question is, would this be a main processor or graphics card issue? Either way, I would have thought this system could handle it. Or is there something I need to set to make this work? The second question concerns hard drives. Premiere recommend a striped RAID array but it suits us much better to work off a standard SATA 7200RPM drive, as we have a lot of material coming through and we archive it all to hard drives so the editors need to just plug a drive in and get the edit underway. (The drives are cold-swapped into a SATA slot on the front of the machine). Copying to the SAS array and back again would be time prohibitive. We found that we can work off the SATA fine, it makes no difference. So at what stage of the process is the drive speed the critical factor? Is it generally accepted wisdon that Intel systems can handle this sort of application or should we have gone to dedicated systems like Avid? Man the learnign curve on that woudl be immense. I like that with Premiere, you can pretty much pull in any amateur editor and they'll be productive quite quickly without anmy specialised training. Thanks in advance for any assistance. |
#2 | |
Mitchell J. Skurnik http://www.mjcsstudios.com/ - EX1, 4x hoodman 16GB, Libec Tripod, Sony LAV |
Three streams of full HD put a killing strain to a single SATA drive. You would be lucky to have just two of them playing off it realtime. You HAVE to use RAID for this workflow.
In addition to the above comments ... Cineform will soon be releasing a CS4-compatible version of ProspectHD. Once a trial of that is available I would definitely recommend you try that out - working with CFHD-codec material is way smooth, and has reduced-intergenerational-loss advantages.
#5 | |
RAIDs offer three primary benefits: performance, data availability (but only for fault-tolerant systems) and storage management. How these rank depend upon the RAID "level" implemented. For your purposes, given your high performance system configuration, an external fault-tolerant RAID is worth the investment. I suggest you familiarize yourself with the technology and vendor's systems and figure out which would work best for you. |
#6 |
Thanks for the replies...in fcat our SAS is a RAID but it's fully redundant so no speed advantage. I can reconfigure it as a striped array but I would be surprised if that cures the problem. As I understand it, the data rate for HD compared to SD is about 50% higher. We never had a problem with SD previewing in real time; so at worst I would expect slightly jerky motion. What we get is updates every few seconds.
Tripp, what would I search on to find out about these external arrays? I presume they would use an optical interface? |
#7 |
Yes, Tripp is right. You can use one disk per camera and get significant speed gain. It just seems like more work than using RAID 0.
#8 | |||
Your RAID doesn't need an optical interface. You can get the performance you need from an eSATA interface. More exotic interfaces will increase cost and, potentially, complexity that you probably do not need. I'll have to defer to others who have purchased and used RAIDs in their systems for recommendations since I've not bought one myself, although I get momentarily tempted on occasion. If you check with the DVi advertisers and others who sell RAIDs for video you will start to see a pattern in the specifications. I suggest you chat up a couple of these vendors. The good ones will point you in the right direction. |
#9 |
I have also noticed this problem. It has nothing to do with a raid at all. In fact I have CS3 and CS4 on my system and CS3 works perfectly. On CS4 I can take the exact same media and it will not play back very well at all and this is with a single stream. I have a quad core system and in CS3 HD plays perfectly.
I have read a lot of problems sort of like this on other user forums with little to no solution to fix it. From what I can tell it looks like a gpu issue. CS4 changed the way it deals with the gpu so CS3 plays back in a different way then CS4 does. A few users seem to have fixed the problem by shifting their Nvidia drivers more to "performance" instead of "quality". A few deactivate direct3D support and that helped. I have an ATI card and so far everything I have tried didn't fix the problem. Just to add a bit more info to this. I installed CS4 on my single core laptop with a ATI X600 video card and CS4 plays back HD much better then my quad core system. The laptop is loaded with all sorts of junk while the quad core system has a brand spanking new formated setup of Windows XP with no fluff at all. I am going to experiment with different ATI driver versions this weekend but sadly my video card the 4670 is pretty new so I only have a few drivers to choose from. So far I have used the 8.11 drivers. The Adobe website has a list of supported video cards with openGL support for After Effects CS4. I know it isn't Premiere but they list the ATI drivers tested and those are the 8.8 drivers. This leads me to think the 8.8 drivers may work fine. I don't think the 8.8 drivers will work with my video card but maybe other people can try this out. If you are a Nvidia user like the first person who posted here then try reducing the performance of the card to see if that helps. You may also want to check out that same AE CS4 page to see what drivers were tested by Adobe. Hope this helps. |
#10 |
If you are editing EX footage in its native form (.mp4 or .mxf files) a single modern SATA drive should be more than sufficient for multiple streams. EX footage is only 4MB/s and a drive can sustain around 100MB/s although it isn't always that simple since I/O count and other factors have to be considered. Are you just referring to desktop playback for you performance analysis, or are you trying to go full screen to a second monitor?
For more information on these topics, check out my tech website at www.hd4pc.com |
