can't find 8 and 16 point garbage matte handles at DVinfo.net
Adobe Creative Suite
Old December 14th, 2008, 07:24 PM   #1
Need some help. I have Premiere CS3. I've been trying to use the 8 and 16 point garbage matte in a project. However I can find the handles in the preview window even if I click on the effect to make it visable. I have done a search here in the forum but no luck. Any help would be appreciated. Thanks
Harry
Harry Lender is offline   Reply With Quote
Old December 14th, 2008, 08:20 PM   #2
Try zooming the preview window out a bit...it might be outside the box
Mitchell J. Skurnik
http://www.mjcsstudios.com/ - EX1, 4x hoodman 16GB, Libec Tripod, Sony LAV
Mitchell Skurnik is offline   Reply With Quote
Old December 15th, 2008, 06:30 AM   #3
I tried that....No luck. Thanks for your reply.
Harry
Old December 15th, 2008, 10:45 AM   #4
Try clicking on the effect in the effect controls window. I seem to recall you cannot access the points until you hilight the effect, simlar to how you cannot move and assett until you click on the particular parameters in Premiere. I hope it is as simple as this.
Marty Hudzik is offline   Reply With Quote
Old December 15th, 2008, 12:27 PM   #5
I also tried that. No luck. I can only move the matte with the numbers after I click on the triangle twirling the controls into view but that's a pain to do. I know in the earlier version of PPro I could see the handles but not it CS3. Oh well I'll try some other things. Thanks for you replying.
Harry
Old December 17th, 2008, 12:58 AM   #6
There is a problem with garbage matte handles in CS3. When I do get to see them they bear no relationship to the area I'm trying to matte...
I read of one workaround (Adobe - should we really have to find a workaround ?!) and that is to place a copy of the clip you're working on on the timeline above the main clip and apply the matte to that. It does work, though I don't know why...
Old December 17th, 2008, 07:04 PM   #7
Unfortunatly it did not work for me. I tried it several times but with know luck. Thanks for trying. I'll keep trying.
Harry
Old December 18th, 2008, 01:01 AM   #8
Harry, try applying the matte to the lower track then - it might have been that...
Old December 18th, 2008, 09:01 AM   #9
Robin
Thanks so much for taking the time to check this out and trying to help. Your last suggestion did not work. I then tried opening the clip up in PPro 1.5 and applying the sixteen point matte to it there and all the handles were visable. So then I went back to CS3 and tried again with no luck. If all else fails I'll just do what I have to in 1.5, make an AVI, then import it back to CS3. That's the only "work around" I know that works. Thanks again for taking the time to answer.
Harry
Old December 19th, 2008, 08:54 AM   #10
Ya know
Thinking about all this trouble, you would think that Adobe would check things out more thoroughly making sure all the tools and effects work when they release a new upgrade. Makes me think would it be worth it upgrading to CS4? As of this time no. I like PPro but it seems that the quality is going down with each upgrade. Go figure. Anyway just my Opinion.
Harry
Old December 19th, 2008, 09:17 AM   #11
...and yet, the garbage matte works perfectly in Premiere Elements 7 - and in AVCHD as well!!!
Old December 19th, 2008, 09:48 AM   #12
Yes...simply amazing.
Old January 4th, 2009, 04:34 AM   #13
Same problem here in CS4...what's going on here, Adobe?
Colin Zhang is offline   Reply
