CS4 Playback Issue at DVinfo.net
Adobe Creative Suite
Old November 19th, 2008, 06:01 PM   #1
CS4 Playback Issue
CS3 works perfectly with my Sony DSR-25 DV deck - the timeline plays back on the deck's small monitor. But in CS4, even though capture works fine from the deck, and even though CS4 controls the deck when I "export to tape," the video/audio are not going to the DSR-25.
The DV/HDV Device Control is set for the correct deck, all connections still work in CS3, but something is still wrong. Any help is of course appreciated.
Thank You
Paul
FOUND THE ANSWER: The playback settings in CS4 are located on the upper right hand of the monitor inside Premiere ... after some trial and error the playback to DSR-25 works just fine.
Last edited by Paul Budline; November 19th, 2008 at 06:15 PM. Reason: Problem solved
Paul Budline is offline   Reply
