8bit or 10bit for project settings in PPCS3 at DVinfo.net
Adobe Creative Suite
Old September 26th, 2008, 01:57 AM   #1
When I start a new project in PPCS3 should it be in 8 bit or 10bit? What’s the difference. I don’t know much about bits, I would assume that 10 bit is better. Can anyone enlighten me on theses settings.
Also when I go to prerender a section what format is this rendering to and how can I change what format it is rendering to.
I have footage from a Sony Z1, recorded in HDV and this will be down converted to SD MPEG-2 for DVD duplication if I find that PPCS3 is what I use.
Nick
Nick Stone is offline   Reply With Quote
Old October 6th, 2008, 03:03 PM   #2
found this on the web, hope it helps
Why Video Bit Depth Matters
Devin Termini is offline   Reply With Quote
Old October 8th, 2008, 01:17 AM   #3
For HDV, 8bit is fine. Unless you have Cineform or a third party I/O card, you should use the HDV project preset for best performance, which doesn't have a 8/10bit setting.
For more information on these topics, check out my tech website at www.hd4pc.com
Mike McCarthy is offline   Reply
