donw scale an FLV file, help please at DVinfo.net
Adobe Creative Suite
Old September 16th, 2008, 06:51 AM   #1
Hi there, i'm not shure if this question belongs to here but anyway i use APPRO CS with Matrox RTX2, i need to make some movies to the web so i was asked to create them in FLV, the question is that i want them to be 400 wide but when you export to FLV in 16:9 if you change one of the size parameters you don´t know the other one, so how do i calculate the real size so that it wont cut or show what i don´t want to? By the way when i compress what codec should i use? And the frame rate should i live 25fps?The audio file bitrate so that i have i nice audio quality without making the file to big?
Thank you for your help,
best regards,
Luís
Luis Ventura is offline   Reply With Quote
Old September 16th, 2008, 06:59 AM   #2
Well to get 16*9 multiple 400 by 9 and divide by 16.
So you will be 400 wide and 225 tall... 400w*225h
If you want to hide certain things the next step would to be to use the crop tool in the encoder window.
For that size I would recomend the on2VP6 encoder and a bitrate of about 768K for the video. I am not sure without looking but the default audio should be fine.
Simple Thought Productions - Life @ 30,000 Words per second
Josh Chesarek is offline   Reply With Quote
Old September 20th, 2008, 07:10 AM   #3
Thank you Josh, I will try that.
Best regards,
Luís
Old September 22nd, 2008, 11:20 AM   #4
Luis,
I export all of my product videos as FLVs at 400 x 225. You can see the result here. I get great quality and the buffer time is n/a once you hit "play."
GM Fog Light Bulbs by Putco and other Bulbs available at StylinTrucks.com
Will Mahoney is offline   Reply
