Displaying Audio Graph in a video at DVinfo.net
Adobe Creative Suite
Old August 3rd, 2008, 06:21 AM   #1
This could probably go in any forum but as I'm editing in Adobe Premiere 1.5.1 I'll put it in here.
What I want is to display a audio graphic like ( http://oldsite.prometheusradio.org/c...r_graphic1.jpg ) but play it out in the video so the bars move?
I'd either want the whole audio clip and a bar moves left to right or the audio that is actually playing is displayed on screen?
Is this something I can do in premeire or is there another program then I just import the video?
Hope it makes sense!
David Dwyer is offline   Reply With Quote
Old August 3rd, 2008, 06:25 AM   #2
you can cpature some display , like in winamp or use a plugin, but the price will be a lot more higher.
check http://www.trapcode.com/products_soundkeys.html
Old August 3rd, 2008, 12:02 PM   #3
You might be able to make something in Premiere... What if you:
1:Took a screen shot of the entire waveform,
2:brought it into Photoshop to resize and crop it,
3: Lay it onto your timeline as a graphic,
4: create a vertical bar in the Titler, and
5: Just animate the vertical bar to move across the waveform in its own layer above the waveform graphic.
I think it would be pretty easy. Just create 1 keyframe with the bar on the left side of the graphic, scrub to the end of the song/sound, and then create a second keyframe with the bar on the right side. Hope this helps.
Shawn McCalip is offline   Reply
