MPEG Stream error while rendering at DVinfo.net
Adobe Creative Suite
Old June 27th, 2008, 08:45 AM   #1
Seems Premiere is just throwing all it has at me. All using Adobe Media Encoder (the unknown happens in both that and regular movie outputting) First the "Error Unknown Error". That pops up...well whenever it wants while trying to export. The the "Did not return video frame" error...which was ...'solved' by making a new sequence a few times and moving everything onto video 2. I called Adobe Tech Support and they told me to start my project over. But now its getting about 90% through and giving this error
"videoname.m2tError in MPEG Stream detected around frame 492"
I tracked down said file name in the project and scrubbed through it. Some frames turned all red like premiere likes to do when its dumb. I opened the source file in the monitor, no problem at all. So I re-edited the file on the time line (was split in 2...so I deleted the 'corrupt' part and re-split where needed the first half), pre-rendered, it was was fine. Then rendered just a 30 second clip around the 'corrupt' area with Adobe Media Encoder, worked perfectly fine, looked delicious. So I tried rendering the whole 18 minute short, and again got the MPEG Stream Error. Whats the deal? Why is Premiere being such a jerk to me?
Cinematography Site
Nathan Quattrini is offline   Reply With Quote
Old July 2nd, 2008, 06:30 AM   #2
Hi,
I had similar problems when I captured in Sony Vegas and edited in Prem pro.
Do you capture in PP?
// Lazze
Sony HDR-CX130,Canon 5DMKII,i7 930@4.0, 12gb memory, 3x SSD + 2x1Tb(stripe), Geforce 480, Dual 24", Win 7 x64
Lars Siden is offline   Reply With Quote
Old July 2nd, 2008, 06:41 AM   #3
Captured with HDV Split
Cinematography Site
Old July 3rd, 2008, 12:25 PM   #4
try to capture some clips in PP and try to render them out to MPEG, if that works...
// Lz
