Spinning Newspaper Headline Effect at DVinfo.net
Adobe Creative Suite
Old June 24th, 2008, 03:14 AM   #1
Can anyone suggest how I may create the old and tacky effect where a front page newspaper headline spins towards you and stops, revealing the headline?
Interesting, if true. And interesting anyway.
Hugh DiMauro is offline   Reply With Quote
Old June 24th, 2008, 03:34 AM   #2
quick reply of the top of my head
start of clip:
scale = 20% (roughly)
rotation = 5x0.0deg (roughly, to get you a few rotations)
end of clip
scale = 100%
rotation = 0.0deg
then muck about with keyframe interprolation to make for a smoother start/finish as necessary
if u wanted to get fancy, you could do the same in After Effects but with motion blur
Richard Wakefield is offline   Reply With Quote
Old June 24th, 2008, 08:59 AM   #3
Thanks, Richard
I kinda knew the technicalities. I was hoping for a lead on some preset I could download from somewhere. I am really in a crunch. I need a ready-made clip I could just use with the headline already in place. I can insert my main character's photo.
Old June 24th, 2008, 12:06 PM   #4
I haven't looked deeply into it, but isn't there a preset transition like that in Windows Movie maker? might be a way to export it.
Bill Mecca is offline   Reply With Quote
Old June 24th, 2008, 03:55 PM   #5
Bill! I hope you're right!
I will see if I still have Windows Movie Maker on my comp. That is exactly what I might be looking for. I tried to make a phony newspaper front page with Microsoft Word but cannot figure out how to import it on my Premiere timeline!
Old June 24th, 2008, 05:51 PM   #6
It's so easy and quick to animate it in Premiere, I think you'll end up spending more time trying to find something ready-made than if you were to just click in a couple of key frames. It's as easy as Richard up above puts it. Basically, about 6 clicks of the left mouse button. If it were me, I'd make it something more like 20 full rotations instead of 5, and then I'd apply the Radial Blur effect, make sure it's set to "spin", and then make sure you have the blur amount keyed to 0 when your newspaper finally stops spinning.
Shawn McCalip is offline   Reply With Quote
Old June 24th, 2008, 07:14 PM   #7
Shawn:
How do I import the Microsoft Word document into my Premiere timeline as a clip or still?
Old June 24th, 2008, 09:04 PM   #8
Originally Posted by Hugh DiMauro View Post
Shawn:
I print the word file to a pdf, open the appropriate page of that pdf in Photoshop (which coverts it to a bitmap), trim/resize it to the required aspect ratio and resolution, and then save it as a image file (bmp, tif, or jpg) for loading into Premiere or AfterEffects.
There may be quicker ways ......
Old June 25th, 2008, 01:32 AM   #9
Thank You, Graham
Allow me to monkey around with that. I did find something on the web that might help as well. Dang this last minute scramble! If I wasn't so lazy I'd be knowing this stuff through practice during the down time.
I admit that I'm so lazy I wouldn't yell "sooweeee" if a hog was gnawin' on my butt!
Old June 25th, 2008, 09:33 PM   #10
Hey Graham:
I found a program which converts the file into a .tiff. Thanks for your help.
