Premiere Pro CS3 won't start up! at DVinfo.net
Adobe Creative Suite
Old June 3rd, 2008, 03:31 PM   #1
I was editing in Premiere Pro CS3 and it locked up on me recently and I was forced to shut the computer down. Since I rebooted and tried to launch the app again, it goes through the motions where I can see the title screen but then "poof" it fails to launch. Trying to repair the installation, re-installing Premiere CS3 or uninstalling and reinstalling the app does not work either. I even tried to restore to an earlier restore point but that did not work either. Any suggestions? (Premiere Pro CS3, Win XP SP2 Home, Dell Core2Duo pc. I haven't done anything else to my system, everything worked fine until Premiere Pro CS3 crashed last night)
Jim Gunn is offline   Reply With Quote
Old June 3rd, 2008, 10:27 PM   #2
C:\Documents and Settings\{USERNAME}\My Documents\Adobe\
Delete your premiere pro settings and that should fix it
Mitchell J. Skurnik
http://www.mjcsstudios.com/ - EX1, 4x hoodman 16GB, Libec Tripod, Sony LAV
Mitchell Skurnik is offline   Reply With Quote
Old June 4th, 2008, 01:39 PM   #3
Thank you so much. That did the trick! The Adobe tech support guy had me deleting or moving another one of the Adobe preferences folder. I think it was the one under Application data, but that didn't fix it, and I couldn't create a new user i.d. because then Cineform Aspect HD wouldn't work anymore.
Old August 15th, 2008, 07:08 PM   #4
Thank-you!
Thank-you so very much. This worked for me also.
I had also 'repaired', 'uninstalled', 'system restored' and created a new Windows user account. Creating a new user account did work, but I really wanted to know what caused the problem in the first place.
Again, thank-you thank-you thank-you.
I'm working on a Vista x64 machine, and was hoping like heck is wasn't some phantom x64 problem.
Cheers!
- Andrew
Andrew Strugnell is offline   Reply With Quote
Old August 16th, 2008, 10:26 AM   #5
PPRO CS3 won't start up
This hasn't happened to me yet but just in case which folder do the settings reside in?
Harry
Harry Lender is offline   Reply
