HINT - how to turn off frame blending at DVinfo.net
Adobe Creative Suite
Old May 6th, 2008, 01:19 PM   #1
Before you start putting clips on the timeline, select your video clips and go to clip->video options->frame blending.
From now on, any part of this clip that you put on the timeline will have frame blending turned off.
Stumbled upon it by chance today, but I believe this might be helpful to many people here.
Remember, do this before you start editing :)
Bart Walczak is offline   Reply With Quote
Old May 7th, 2008, 09:07 AM   #2
The same goes for deinterlacing. But why Premiere doesn't allow this for multiple clips on timeline I'll never understand.
Thanks for useful tip Bart!
Jiri Fiala is offline   Reply With Quote
Old May 7th, 2008, 10:19 AM   #3
and why would I want frame blending turned off Bart?
Old May 7th, 2008, 02:15 PM   #4
I'm curious about this as well. What are the advantages/disadvantages of turning this on or off?
Old May 7th, 2008, 07:45 PM   #5
when your working in 24P,for example, if frame blending is on the clips appear to have a strange "fluidity" to them. As if they were some strange interlaced field order. They do not look like 24P, and it is most obvious if you export to a DVD. It is extremely annoying, and has been a battle for us at work for a long time.
This is of the utmost help to us, and I am incredibly grateful for this insight, thank you Bart, for this post. You may have just saved hundreds of headaches.
Benjamin Richardson is offline   Reply With Quote
Old May 8th, 2008, 10:44 AM   #6
So just to follow up a little, is this then not an issue/necessary/of benefit if you only work in 60i?
Old May 8th, 2008, 11:35 AM   #7
Frame blending seems intended for interlaced footage, it is only a problem in progressive footage.
Frame blending also seems to help in certain situations where a clip's speed has been decreased.
-Ben
Old May 8th, 2008, 12:25 PM   #8
I was under the impression that frame blending only applies to clips that have speed changes, and doesn't affect clips playing at normal speed. I haven't noticed a difference with it on or off with my 24F footage. Maybe I need to look again. Thanks for the tip.
Kevin Dorsey is offline   Reply With Quote
Old May 8th, 2008, 06:41 PM   #9
Yep, a little further digging shows Adobe's assertion that this only applies when changing speed.
http://livedocs.adobe.com/en_US/Prem...8aef7-7cd8.htm
http://livedocs.adobe.com/en_US/Prem...aef7-7d15.html
But I'm still not sure why it should be turned off, even in 24p mode, if you're not changing speeds.
Old May 8th, 2008, 08:34 PM   #10
I find that "Frame Blending" enabled seriously slows down render times..
Crisp footage takes a serious hit, never mind choosing deinterlacing method.
For me, personally, it's hit and miss, and i only check it if i absolutely have to.
All my interlaced footage is monitored through a broadcast CRT. Depending on the speed change and camera movement, Frame blending might be required. Otherwise, i've noticed that having Frame blend unchecked, gives me cleaner results..
Old May 13th, 2008, 03:41 AM   #11
When you try putting 50p footage on 50i timeline, you will understand why you need to turn off the frame blending... :)
Plus it does make rendering time about 4x as long as without it.
Old May 13th, 2008, 01:52 PM   #12
Originally Posted by Bart Walczak View Post
When you try putting 50p footage on 50i timeline...
Oh, okay, got it. Does anybody do this? Does any camera actually do this?
So if I'm understanding you correctly there's actually no reason to do this if you're just shooting normal 60i video...
Old May 15th, 2008, 02:52 AM   #13
JVC HD-101.
Yes, if you're just working with normal 60i, no need to turn off frame blending.
Old May 15th, 2008, 06:45 AM   #14
Would this have anything to do with slower render times in a DV 24p timeline?
Vince DAmbrosio is offline   Reply With Quote
Old May 20th, 2008, 02:21 AM   #15
If you're using native 24p footage, unlikely, but why don't you simply check it out :)
